![]() | Home > Td5 > vnt turbo |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 677 ![]() ![]() ![]() |
Last weekend I have upgraded map in Disco 2 TD5 with auto gearbox and bigger torque converter - from very old (original 2001) standard map to the latest one standard map. Difference in driveability was big. Next step will be some slight power upgrade.
Difference between map in even older MSB ECU and latest map in NNN ECU is even bigger. Not in maximal power, but smoothness of the power delivery. With all your changes, like upgraded MAF and different turbo, and standard very old software in MSB ECU the result cannot be good, possible a bit better than original setup. If you have NNN ECU try at least newer standard map. And then switch to proper remap suitable to your turbo and other upgrades. Take out boost box and power box. Boost box is only good for tuning of new turbo, to limit a bit protections in ECU, but not good for proper work. The same with power box - with proper remap you get better results. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Gerry Member Since: 22 Oct 2017 Location: north Ireland Posts: 35 ![]() ![]() |
I was the other guy mentioned the boost box but I had misread the opening post as I thought you had all the other performance enhancing upgrades fitted but were still running the stock turbo and standard remap but as that's not the case disregard what I wrote and sorry for the confusion. On another note, you wouldn't happen to have any experience with this you'd like to pass on. https://www.turborebuild.co.uk/webshop/pro...ridge.html |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Gerry,
Already installed, but to take advantage of the new lower performance, i need to remap. I found the turborebuilts can make me a hybrid turbo for the BMW M57 and only 375 plus shipping. Its 55 pounds for the performance billet impeller, 50 pounds core, 245 pounds for the cartridge, and 25 pounds for balancing the new impeller in the new cartridge. Its the cheapest price with the highest quality i have seen. I have a dawes device, which helps with controllin the boost and keeping it as much linear as possible. No spikes in pressure, and no sudden drops either. Now do i go with my frankenturbo, BAS' VNT or Allisport's VNT? Since i am at a stand still i will just swap my 10P for my built 15P and install the new Alive turbo and ECU and just roll it that way. Enough buying, its time to just drop the hammer and play with the cards i was dealt with...If i have the need for more power then its a matter of swapping in a larger engine and turbo and calling it a day... |
Change in direction, it looks like i am goin to get the turbo from a mercedes sprinter, GT2256v basically, but i will also get the bmw gt2256v turbo, take the compressor housing from that one out, modified by turbo clinic and installed on the merc gt2256v.
The merc cartridge, will have to be modified where i take the vane control and install it on the other side for top mounted actuator. Its a bit more machinary work, but this should take me in the direction and give me dependable performance with dependable parts. |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Have you considered the hybrid td5 turbo from alive with a stage 4 tune 210bhp easy 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
I already have it, but havent installed it yet as it was tuned for a 15p and i currently am lookin to see what my 10p can do for me first.
Remappin will be from storm tunin, as they replied quickly and said all the right things when chatted with them... |
Naf, sorry for the late reply.
From from firsting enquiring about the Turborebuild I have since fitted one and like you i too am well pleased with the quality but i know my existing remap isn't doing it any favours regarding lag at low revs, I hear the turbo spooling up faster but the extra performance really kicks in higher in the rev range, I've tried experimented with the wastegate to no avail so I'll get Jose (TD5Inside) to cure that on his next visit. The whistle from the new turbo is also a nice addition. |
Gerry,
Its cool, this is a forum. You have an upgraded Innercooler? You are absolutely correct, you need to remap her from bottom to top. I found that the turbo likes to be around 21psi, but you have to be careful, the new hybrid turbo doesnt like pressures above 22psi. I run 16.5psi normally, and when i press the button i get 21.5psi. I recently installed another type of chip box that plugs into the MAP sensor, just to see what would happens, but my clutch system decided to kick the bucket before i could try it out. I am hoping this weekend to see my gains. May i also suggest an engine oil additive that for me has proven its self over and over again. Its called Microlon. Its a one time application where it helps coat and protect your moving parts from friction and heat. I used it on my boat, race car, and daily driver, and i saved on fuel mileage, and the acceleration is quicker. I also added their C90 to other areas like the diffs, gearbox, and transfercase. My transfercase is currently suffering from high heat at 130kph, i hit 250F. I now have swapped to an ATF fluid to see if that helps lower the temp, Last edited by Naf on 9th May 2018 9:35am. Edited 1 time in total |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2506 ![]() ![]() |
Naf I see you are suffering from high transfer box heat, you can buy a bigger sump from ashcrorft or syncro to run more oil capacity and thus more cooling affect? 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
I already have it installed with the roamer drive...
I was considering adding an external oil cooler with fan. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I know I've read of people installing oil coolers for the lt230. Might not even need a fan of the rad is mounted in a good spot. I do believe that you need to pump the fluid yourself though, as the box isn't designed around having an external cooler?
I completely agree with you, that is why I have a external vdo gear oil pump that will be electricly driven as well as a fan will be activated once the pump is energized
Yes Naf, I've fitted the AlliSport intercooler & silicon hoses to complete the uprated turbo upgrade.
I'm hoping Jose does the retweak on his next visit at a reduced price and I feel he will as he told one of the other guys he'd improve his remap next visit at no extra charge once he got a heavier duty clutch installed. All understood on the Microlon additive and I'll be following that advice. ![]() |
I bought a replacement clutch from Ben at clutchfix, only guy i would trust as he knows what type goes where. And dont be fooled by this whole dual mass crap. Its just comfort, no impact on the gears. Those are crap from the factory...
