Home > Maintenance & Modifications > What jack do you have?
Page 3 of 3 <123
That's very nice, but $1000 Shocked Is it twelve (approx.) times better than a high lift? Darren
Post #697237 30th Mar 2018 4:51pm
$1000 plus shipping converted into GBP Β£ then add handling fee, goods value VAT @ 20% plus finally customs fee which is around 2 - 8% I think due to Β£125 + goods value.
So rather quite a lot of money..... Shocked ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #697247 30th Mar 2018 5:37pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Got a bottle jack from a merc van Smile
Post #697320 30th Mar 2018 9:52pm
VVS210
Ditto - use it with a piece of cut down waffle board on soft ground. Also drift the pin out & remove the U shape on the ram & replace with a large washer to jack up the D4.
Post #697322 30th Mar 2018 10:35pm
Timo K
Finland
While it is expensive (ouch...) I think that ARB hydraulic jack looks the bees knees. Hi-lift works, yes, but it can be finicky. Doesn't like the slightest bit of dirt and operating it can be sketchy.
I'll be getting one of the ARB ones when they release it and get rid of my hi-lift. Should be far easier to operate.
Post #697337 31st Mar 2018 6:18am
arran jones
I dont have any proper jacking points
I.e. i have a normal bumper, sills and crossmember
I do quite a bit of offroading and have a hi-lift Jack and also waffle boards
I wus thinking of using the waffles for a base on soft stoney ground
My Q is
Where would the best place be to jack mine up front and back??..some where, where its not going to damage anything
Mt
Arran
Post #698347 3rd Apr 2018 9:30pm
You have got proper jacking points, front and rear. Underneath the front bumper are two inset tubes with rubber bungs in them, and in the rear crossmember are also two inset tubes. You can buy an adapter for your hi-lift that will enable you to use them. Darren
Post #698351 3rd Apr 2018 9:37pm
You have to be a bit careful with the Merc jacks as they're quite a lot taller than the LR equivalent. If you get a flat tyre on the off-side, if can be a challenge to get the taller jack underneath the thicker axle casing, particularly if you need to use a spreader board of some description. Darren
Post #698354 3rd Apr 2018 9:45pm
All of the above that LRA suggested.
If you go to Thornton Breakers you can get a brand new Genuine take out jack for easy the same price as that merc one. ____\We|Will|Win/___
Post #698358 3rd Apr 2018 10:14pm
I used my new Hi Lift I had today for the first time, funny enough not for my 90 though.
It did an excellent job of lifting out some fence posts set into the ground. (Not concreted.)
Bolted a piece of 75x75mm timber vertically to each one with some long m10 tested coach bolts 2x and the jack pulled them straight up and out with ease.
Great bit of practice that is safe too, saved a lot of work!
I'm glad I bought it as it can do multiple jobs.
Mr. Green ____\We|Will|Win/___
Post #729096 15th Sep 2018 4:12pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
TMax 4ft jack for me
Half the price of the high lift and after 4 years of living on the roof rack it still works fine. Great bit of kit that I've used for everything from changing the wheel off road to lining up the front skid plate while trying to fit it Laughing
I originally bought the 4ft because it fits behind the seats perfectly, but it takes up less room and looks far cooler outside Cool
Bottle jacks are fine for tyres, but are naff all use if you need to take the weight off the axle. 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #729115 15th Sep 2018 7:54pm
They have their uses. Thumbs Up ____\We|Will|Win/___
Post #729119 15th Sep 2018 8:09pm
Gilloverland
Ex TD5 Disco bottle jack for me and a Hi-Lift.
Post #729191 16th Sep 2018 9:08am
dorsetsmith
Ex TD5 Disco bottle jack now installed also t bar jack and a Hi-Lift but not for jacking landy but splitting logs and ex sprinter 3.5 bottle jack for service work
Post #729194 16th Sep 2018 9:17am
Page 3 of 3 <123
