Home > Maintenance & Modifications > Optimill Swivel Lock Cover
Page 2 of 2 <12
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Another layer of security can't hurt! I think it is a great visual deterrent and money well spent... Thumbs Up Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #697738 1st Apr 2018 7:52pm
L110CDL
I would agree with all that the lock is a great bit of extra security and is doing it's job really well Wink Clayton.
Keeper.
Post #698126 2nd Apr 2018 10:33pm
stephan123
Another Thumbs Up for the Optimill QR boss/Swivel Lock combo!
Post #698127 2nd Apr 2018 10:35pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
One of the best bit's of kit on the market
I have drilled a small hole on the inside shell to make it easiy to fit you can just feel with your finger which way to turn to help locate the pins, I too use it very day somtimes 3 or 4 times on and off and no sign of wear
Post #698154 3rd Apr 2018 8:41am
legin
Butchers boy said "I was thinking he has only got to clock what steering wheel I have" they haven't even got to do that a pair of mole grips do the job enough to drive away Crying or Very sad
Post #698158 3rd Apr 2018 8:49am
Sulisuli
Legin would it be possible to see a picture of the holes and where you have drilled them to assist fitting this as there is a knack to fitting it and any assistance would be appreciated Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #698365 3rd Apr 2018 10:23pm
legin
To late to go down the workshop tonight and I have a job in the van early in the morning will try and get picture in the afternoon when I get back.
Post #698370 3rd Apr 2018 10:30pm
Sulisuli
Thank you. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #698378 3rd Apr 2018 10:44pm
legin
Here's my tip for fitting a Optimill Swivel Lock, First when removing the lock take out the key so the lock is in a unlocked position and always make sure the steering wheel is level .
This means when offering the lock back up to the dock all you have to do push in the lock ,save's having all your keys getting in the way .Next look inside the lock and in the inner shell drill a small hole above the top location pin.
Now when offering the Optimill Swivel Lock with the steering wheel level you can just feel with your finger where the hole you have drilled is and with a 5 to 10mm movement either way the two bottom pin should locate.
Now just push the lock home
With a bit of patience I can normaly nail it nearly very time .
Post #698654 4th Apr 2018 9:41pm
Sulisuli
That’s clever drilling the hole Thumbs Up because fitting does require a little patience and a knack. Thanks. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #698655 4th Apr 2018 9:51pm
legin
Let me know how you get on.
Post #698656 4th Apr 2018 9:53pm
Sulisuli
Did the drilling today and yes it does work Thumbs Up top tip thanks for sharing. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #698995 6th Apr 2018 5:08pm
Page 2 of 2 <12
