Home > Maintenance & Modifications > Which Intercooler
Grenadier
Which Intercooler
I used the Search function and found some good general info on members' POV on various intercoolers, but none as a comparison. As such, has anyone seen/fitted/tested more than one make?
The obvious ones I am interested in, (perhaps) in order, are as follows:
Alive
BAS
Allisport/IRB
Twisted
I cannot decide which one. Heard good things about Alive and BAS, mixed views (quality) on the Allisport, and the Twisted (as with everything Twisted) seems to be £150+ more expensive than the others for no apparent reason. That's the cost of some silicon hoses.
Any thoughts? Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #697401 31st Mar 2018 11:07am
bankz5152
Allisport in mine over a year with no issues at all. Plus lifetime warrenty
I did have a Britpart one in my 90 which was slightly smaller than the Allisport but did the job well enough!
Post #697402 31st Mar 2018 11:15am
ericvv
In addition to the 4 you mention, there is a very good one available from a German supplier. Actually produced in Austria I believe. I have this installed for a few years now. Perfect.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #697403 31st Mar 2018 11:17am
Zed
£150 more gets you.. err a Twisted logo.
Post #697405 31st Mar 2018 11:20am
Grenadier
^^^ Done. Always a sucker for a logo Whistle Monsieur Le Grenadier
Post #697413 31st Mar 2018 11:58am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Allisport here. Np at all and great service.
I don't think Alive makes them or do they?? I thought they used allisport.
Got the radiator from them as well Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #697420 31st Mar 2018 12:25pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Used Alisport for 200k miles on my old 300 tdi - no problems - BUT have just had the BAS intercooler fitted to the 2.4 puma because my experience with the BAS RRC2 has given me great faith in Pete's customer support - more or less instant and accurate. Thumbs Up
Post #697424 31st Mar 2018 1:21pm
doncarloz
Austria 2015 Defender 110 Puma 2.2 DCPU Stornoway Grey
Looks like a Chiptech-Intercooler to me.
http://www.chiptech.at/defender_ladeluftkuehler_chiptech/
Post #697429 31st Mar 2018 2:03pm
ericvv
The Alive Ultimate Defender intercooler indeed looks very much like the Chiptech intercooler. The Entreq intercooler which I have also seems the same one from Chiptech. When you work out the forex, the prices of Entreq and Alive are virtually the same, so would say buy basis the best shipping cost depending your location. As said, I have this intercooler from Entreq, it is really a plug 'n play perfect fit, and no chance that this Chiptech ever will split its welds under the pressure.
Post #697435 31st Mar 2018 2:21pm
jst
i have an Alisport one in my 110 fitted 2012 or similar, no problems with it
have an Alive Ultimate 1 in my 90 softop. fitted last year
they both work, neither gave it immediate extra oomph, both lowered engine coolant running temps under load.
much a muchness really. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #697447 31st Mar 2018 3:53pm
pannawonica
Australia
I have an Alive intercooler the top one! Now out here alisport don’t get a nod because of failures. This may not be a problem in the uk, however with postage out here, once bitten! They may be now a top draw product and with excellent customer service, I dont know. However the the Alive product works better at plus 50C than Land Rover at 35C ambient. It’s built like a brick ...you know! Could be wrong I seem too think it’s Austrian.👍
Post #697608 1st Apr 2018 12:25pm
Out of interest, did you change coolant and replace with original fluid or replace for brand new fluid?
How many degrees roughly running temp difference did you notice?
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #697624 1st Apr 2018 1:16pm
jst
No same coolant
Pulling 3.5t uphill at 60mph over 2-3 miles temp 8-10deg lower as shown on scsnguage when compared to same setup and loading and ambient over std intercooler. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #697648 1st Apr 2018 2:48pm
Quite a reasonable gain then.
Reason I asked was because when I changed my coolant over that reduced running temp a little too.
So, as you've used the same coolant it definteky goes to show the updated intercooler is doing its thing as it should.
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #697651 1st Apr 2018 3:37pm
JOW240725
I went for the BAS Hi-Flow because I liked the research he did and published. It was developed to be optimal for the Puma engine so seemed a sensible choice to me. It was also however that I wanted a package deal with remap, seemed to make sense. James
Instagram @suffolk_rovers
Post #697784 1st Apr 2018 10:33pm
