![]() | Home > Maintenance & Modifications > Front Window Wind Deflectors |
stick on hands
![]() 1968 1/32 scale Britains 109 Pick up. |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
didn't forget you, i just fit them both, front and rear. rear exellent, front i had to cut a little here is the result ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Nice, I have some on order... QRZ M8VPF
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Just tryed to do this again and broken it snapped clean in half and i warmed it up in sun for ages HELP !!!!!
Surpose i had better order some more on the net where do i get the stick on ones then ? might be my only option If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
I managed to kill two sets from ClimAir. I tried everything (I had 4 to practice on) but no matter what, the thin lips that go into the window slots always broke. I used the "spreader" clips (even bought some extra) and when I did manage to get one looking okay, the electric window motor couldn't push the window up. Gave up in the end. I thought it would be a doddle like it was on the Audi but I guess not all Defender windows are the same shape. I can live without them and at least they aren't reducing visibility... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Here is the better option.... When weather is dry, roll the window(s) some or fully down. When it rains, use the ventilation fan... No problems with breaking anything and a perfect fit
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
![]() I had some and sure they're fiddly, but they fit fine, plus with being a short ass, they don't obscure much. I find I use them a lot. QRZ M8VPF |
Genau ![]() But shout it at them in German because life is also terrifying and confusing... |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
heko or climair which are the best quality
Tony Member Since: 13 Mar 2012 Location: West Yorkshire Posts: 72 ![]() ![]() ![]() |
Fitted the ClimAir ones recently and found them really easy to fit but it does require a bit more force to close the window when it's almost fully up. Agree with Odin though, the curved surface gives a distorted view so you need to be careful at junctions etc.
Maybe they'll prove useful for demisting in the winter but if not I'll probably remove them. Cheers, ![]() |
