Home > Maintenance & Modifications > Leaky power steering ? On my Defender TD5
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
Just spotted a pool of thin fluid under my TD5 on the left side. My thinking is it’s power steering fluid but the reservoir is still showing full, any ideas please. Plus it does make a noise turning sharp left.
Regards Terry
Post #696963 29th Mar 2018 3:32pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
What colour is the fluid? Power steering fluid is red and the pump is on the n/s of the engine bay, have a good look around the pipe work and the pump, I have know pumps to fail and start to leak.
Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #696990 29th Mar 2018 5:19pm
Telshe
Hi Will
Thanks for the reply. The fluid under the near side of my 90 was as far as l could tell was clear and thin enough to splash around the main puddle, hope that makes sense. Also the steering fluid is still showing that it is still on the top mark of the built in dip stick. I think l should check the clutch fluid because the clutch slave cylinder is also in that region.
I will let you know when l check. Again thanks for you reply.
Terry
Post #697107 30th Mar 2018 7:58am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Perhaps a silly question Laughing did you recently top up your screenwasher fluid?
I had sort of the same problem and in my case the lid of the washer fluid was leaking a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #697109 30th Mar 2018 8:03am
Balvaig
I always stick a finger in the fluid and taste it. Screenwash is soapy, antifreeze tends to be sweet. Just don't tell health and safety.
Post #697133 30th Mar 2018 9:38am
Tdi4
Rolling with laughter next time i have a leak, i know who to call Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #697135 30th Mar 2018 9:50am
