![]() | Home > Maintenance & Modifications > Hex code |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
What colour is the trailer? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
| gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 128
Why do you need one of these codes?
This the LR code :STC2863VT This is the code any automotive paint supplier needs to mix it - JAM 588 As its a metallic it'll need spraying you won't get a paint that you can brush or roller on! See ..... https://www.defender-landrover.co.uk/p/paint-codes.html Cheers Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
We have online paint webshops in the Netherlands where you can order buckingham Blue Or any other car colour by name.
Perhaps a solution? a defender from 1984 pretending to be a puma with a touch of Range Rover |
| shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 835
Take the easy way out - hand paint the Land Rover the same colour as the trailer
Or buy the cheapest paint you can find and paint both
| Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039
I did think of the trailer colour being dominant but not too keen on painting the Landy in hammerite silver...
We have our own HVLP kits for spraying the trailer ourselves The landy will be wrapped one day but by that time the trailer would've been upgraded to a lorry with the rate of horses we have ( 5 so far and one due any day making 6! ) So those codes you gave ( i found them here before https://www.defender-landrover.co.uk/p/paint-codes.html ) they will work with any compnay that mix's paint for vehicles? What about other paints as i'm more than happy to spray the trailer in Zinsser as we get good rates with this ( and it's properly good stuff ) hence asking for the codes... |
Do you have a link? |
Try these guys always been very helpful
https://www.paints4u.com/ Cheers Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
Www.crop.nl
Great service I guess they talk english. As most dutch do |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
As most Swiss, I speak Dutch too. But Tdi4, euuhhh, are you sure that is the correct website? Can't seem to find too much reference to paint in there. I tried to click the link to "Alles op rolletjes", thinking it might be about a paint roller, but it seems not. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Srry my mistake.
Their company name is crop. But their website adress is www.nonpaints.com a defender from 1984 pretending to be a puma with a touch of Range Rover |
| All times are GMT |
