Home > Maintenance & Modifications > Would it work to galvanize Wolfs to stop them rusting?
CarMan
Maybe they would twist, or too costly Question
Love mine on the 200tdi but fed up with the orange bits Big Cry Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #696771 28th Mar 2018 6:05pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Mine have been powder coated by a dealer for its first owner. Still looking good after 4.5 years.
Post #696774 28th Mar 2018 6:17pm
It's not impossible but the finish can be a bit questionable. I've seen wheels both stove enamelled and powder coated that give a nice, hard finish. Darren
Post #696775 28th Mar 2018 6:18pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I wouldn’t like to say?
But I have seen series wheels that have been galvanized.... 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #696776 28th Mar 2018 6:18pm
CarMan
Good to hear about powder coating, but I had wondered if it would still crack around the nuts just the same as paint and then rust, which the white highlights very badly Crying or Very sad
I was thinking of galvanizing, then painting, so would finish still be a problem? Or maybe then cost prohibitive.
Looking for a durable solution in a classic OE style with a decent turning circle for my old 200tdi - that's all. Otherwise I would put my spare set of Zu's on it. . . . . . . Rob
Post #696781 28th Mar 2018 6:37pm
ian series 1
I would say to have them galvanised properly, they should be spun galvanised to ensure the Finnish is even,
having them just dipped might be too rough for wheels? 🤔 80" 80" 86" 88" 90"
Post #696783 28th Mar 2018 6:43pm
tookaphotoof
I don’t know how my wheels have been prepped as I’m the second owner, but no cracks and no rust. 👍🏻
Post #696784 28th Mar 2018 6:49pm
zsd-puma
RNLI ones are galvanised. So it is possible although it won’t generally be all that smooth.
http://www.alservices.co.uk/workshop/
Scroll down to the bottom of the page - Yes they also have a nice tracked conversion halfway down too. Laughing
Post #696833 28th Mar 2018 9:27pm
Just to clarify - the website linked for the RNLI vehicles says galvanised "wheel rims", does that mean the whole wheel is not galvanised.
Thinking about, once tyres are fitted most of the wheel should not have an issue with corrosion (allowing for a little moisture in the air used to pump them up.
Not seen the wing extensions fitted to the tracked RNLI ones before Thumbs Up
Post #696882 29th Mar 2018 7:20am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I had the wheels on the Series 1 galvanised some 27 years ago and they came out very smooth with no rough areas but I think galvanising can be a bit of a lottery as I have had other stuff done which was terrible and had to go back to the galvanisers for re-doing.
Post #696908 29th Mar 2018 10:20am
No, it's just somebody being casual about describing wheels. The whole wheel is galvanised. Darren
Post #696924 29th Mar 2018 11:24am
Lotus_esprit_s1
Most galvanisers won’t do rims nowadays as liability issues.
I had a batch of 40 boat trailer rims galvanised recently and had to sign disclaimers that they were for off road use only, and even then it was a fight to get them done.
I had a set of tubeless wolfs shot blasted and hot zinc sprayed some years ago and they are still perfect despite living 5 meters from the sea.
Post #697070 29th Mar 2018 9:53pm
CarMan
Ooh that sounds promising and forgive my complete ignorance but is the hot sink spraying a job for bodyshop, wheel refurbishers or elsewhere and would you think that process be available in the OE white? Thumbs Up Rob
Post #697108 30th Mar 2018 8:00am
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I have the standard LD Defender steel wheels fitted. I have just had them powder coated and pleased with the job. It cost £220 + Vat for the 5 wheels. The company did alloy wheels but I think they only do powder coating.
Post #697153 30th Mar 2018 11:28am
Lotus_esprit_s1
It is a specialised process done by metal refinishers and places which do shot blasting. It is the next best thing to hot dip galvanising, and very good for bulkheads too as they don’t buckle! They come back in a rough metallic grey which is an excellent base for painting, and doesn’t need any etch primer etc, so you can spray them any colour you like.
The place I use can then powder coat after the hot zinc spraying if required. I’ve just had pair of 90 cappings and a load of brackets and odds and ends blasted and hot zinced for £90, I’d expect £30 a wheel, but they will never rust again.
Post #697182 30th Mar 2018 1:02pm
