Home > Td5 > TD5 ABS Fault
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
TD5 ABS Fault
I have recently purchased a 2005 TD5 CSW which has a ABS fault according to my Handbook.
The fact is when the car is started the ABS light comes on and does not go on and off as per the system check mentioned on page 51 of the handbook.
The ABS light remains on until the car starts to move at 4MPH also stated in the handbook.
This is said to be a fault situation.
I have already done a search for ABS faults on this forum but did not find anything helpful.
Has anybody else experienced this and if so do you have any ideas as to where the fault maybe?
Thanks
Post #696092 25th Mar 2018 7:28pm
It could be any one of a number of things. The only way to narrow it down will be to plug into some diagnostic equipment, e.g. Nanocom. Darren
Post #696099 25th Mar 2018 8:02pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
Hello MJN, I have a 2004 Td5 with ABS and it does the same, ie when I turn the inigition on and start the ABS light remains on constantly and doesn't go off until I drive off. It never goes on and off and on again before I pull off. Cheers Andy
Post #696104 25th Mar 2018 8:18pm
MJN110
Hi Andy
Are yo unot concerned by this it is quite clear in the handbook that this indicates a fault in the system?
Post #696123 25th Mar 2018 9:09pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
The Td5 ABS light is supposed to illuminate at start-up and remain on until the vehicle speed exceeds ~5mph. This is because the system check includes the wheel rotation sensors. Until the ECU can see that all wheels are rotating the ABS system check can't complete, so the warning light stays on until it has finished. If the ABS light remains on after exceeding ~5mph then there is a fault condition, which may be caused by one of many components not reporting their status to the ECU. Unless you can see something obviously wrong (like a severed or disconnected cable near the brakes) you'll need to get some diagnostics done to locate the problem.
Post #696140 25th Mar 2018 10:04pm
AndyT66
Hello MJN, well I've now read the handbook and the section on the ABS light. It appears it should blink, but as it's serviced by a specialist independent, passes it's Mot each year and stops just fine I'm not unduely concerned. I've done a little research and it appears there could be an old fault code that needs clearing somewhere but as the light goes out when I get to 5mph all is well
Post #696146 25th Mar 2018 10:35pm
miker
I've always understood it to be the light stays on until 4mph is reached as well, it goes off only then after it has checked the wheel speed sensors.
Post #696154 26th Mar 2018 12:26am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
The abs lamp on my one stays on until I drive above 4 / 5 mph as well, think this is correct. I know my abs certainly works as it activated during the recent snow/ice!
Post #696175 26th Mar 2018 8:29am
MJN110
So the question now is does anybody have a TD5 that follows the procedure of the ABS lamp blinking during the start up process?
Post #696191 26th Mar 2018 9:44am
dorsetsmith
Post #696203 26th Mar 2018 10:20am
MJN110
Thank you Dorsetsmith for taking the time to post that information that is just what we need for trouble shooting.
So the ABS light flashes for 0.3 sec would we notice that has anybody seen this happen?
Post #696320 26th Mar 2018 8:01pm
JWL
I can see mine do it if I've recently cleared all the code faults, well clear the sysyem of faults whether they come up or not. At the moment I have a re-occouring speed sensor fault so it soon stays on untill it goes over the 5mph or so.
Post #696342 26th Mar 2018 9:10pm
MJN110
I tried some hard braking today on a dry road today the car slewed to the left and it sounded like one of the wheels had locked up.
This I tried several times with the same result
The conclusion I come to is just because the ABS lamp is not lit up does not mean the ABS is functioning.
Post #696734 28th Mar 2018 3:14pm
MJN110
The latest on the ABS problem is the fault code reader said a wheel sensor fault.
This has now been replaced and apparently the ABS and TC lights come on when the car reaches 60 mph?
Has Anybody else experienced this problem. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #698990 6th Apr 2018 4:46pm
JWL
I'd be inclined to check and double check wheel bearings all round, make sure all sensor probes are clean and sit in the sockets well, I have a front sensor that can start throwing up faults as it soon tells when the wheel bearing is beginning to need tightening as the sensor casing has a slight crease and as such it probably doesn't sit quite as deep as it should.
Post #699049 6th Apr 2018 8:10pm
