Home > Puma (Tdci) > “Clang” when stumping hard on the brake pedal
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I noticed that, with the engine off, car standing still, if I press the brake pedal hard enough, I can hear a noticeable “clang” that I can also feel through the pedal. It seems to happen when releasing the pedal...
The car brakes fine though, but I wonder if that's something I should be worried about... it's a MY09 2.4 Puma with 60k miles on the clock.
Cheers! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #696199 26th Mar 2018 10:13am
jst
rattly brake pads? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #696234 26th Mar 2018 12:28pm
o4dn
Would rattly brake pads cause such a noise even when the wheels aren't spinning? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #696421 27th Mar 2018 10:30am
Balvaig
Just guessing here, but when you actuate the brakes with the engine off you release the residual vacuum from the servo. Could it be the springs in the servo rebounding when you release the pedal?
Post #696441 27th Mar 2018 1:05pm
srod
Yep anything involving brakes and abnormal behavoir is worth worrying about...
Can you have a closer listen, get someone to press the pedal while you go round all four corners try and find out exactly where it's coming from?
Post #696554 27th Mar 2018 8:05pm
jst
yes, actuation of brake pedal pushes pistons out which pushes pad to contact disc irrespective of whether disc is moving or not. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #696571 27th Mar 2018 9:03pm
o4dn
Sounds (and feels) like a spring, seems to be coming close to the pedal itself, possibly from the servo, but not sure... I don't think this is remaining vacuum in the servo because it happens every time, just just once. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #696661 28th Mar 2018 9:38am
jst
the spring that returns the pedal hasnt broken one arm has it? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #696814 28th Mar 2018 8:24pm
