![]() | Home > Puma (Tdci) > Broken turbo studs .. how can I get this stud out? :( |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
That top one with the clearance hole, you should be able to drill out and re-tap the manifold. The one with the blind hole is going to be pretty tricky. Good luck! 2014 Keswick Utility 2.2
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
I would remove it and do it on the bench. I tried the same on my TD5 and went through 3 drill bits even using cutting fluid before I got through it.
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
As bankz says, after much experience of Series exhaust manifold studs (where there is much more clearance) the only way to get a good result is on the bench.
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
As others have said it's going to need the manifold taking off to get good results. If the top one has a hole right the way through then I expect when you start drilling it it'll screw it's self right through and out the other side.
You might be able to find a second hand manifold from a Transit and just swap them over, would save a load of time. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Looking at the angle ,you will never get a drill parallel. Remove the manifold as other have said get a set of "easy out "stud extractors and drill a smaller dia hole than the stud, make sure you drill the full depth of the stud and screw in the easy out which have a left hand thread so as it tightens up it unscrews the stud . Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17857 ![]() ![]() ![]() |
You might get a compact right-angle drill in there, but it will be extremely difficult to drill the stud co-axially along its length.
