![]() | Home > Puma (Tdci) > New MY2011 door uderseal, who know more than me??? |
I will let you know when mine turn up ![]() I can tell you that there are a couple of fixings into the side of the door that look like they will need drilling for. I am not sure if all the fixings are supplied as they did not show on microcat so it could be a while before I get them fitted. Bob |
Mike
We had a look on the latest version at the dealers and it only shows the old style fixings as well. The new seals are shown OK but only old type fixings. There are at least two side fixings which are not applicable to the old style seal and these are not shown so may be included - the parts guy had a good look at the ones fitted to the new defender and said this may be the case - I will find out when they arrive ! Bob |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
They will stop the sheep and dogs escaping?? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Should do and stop the mice getting in ![]() Bob |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 230 ![]() ![]() ![]() |
I've just contacted Ripon LR, they can order in the new seals for £15+vat, will let you know how i get on!
Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Keep us in the picture when you get them/fit them, re: fitting.
El pepe flamenco JLS 'El Pepe Flamenco' |
Just picked my new seals up - £61.20 for the four and looks like money well spent
![]() Fixing is by press in studs, all supplied, so looks like a job of drill the holes, paint the bare metal and fit. That is this weekend sorted out ![]() Bob |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Thank you for this. I have just ordered mine from Britpart. Looking forward to it.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
And spray in some waxoyl ![]() |
Britpart OR Britcar? Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Could you post photos???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Not the best thing to take a picture of !
![]() Click image to enlarge The small black flaps you can see also have black studs in for side fixing. One front and one back shown. Bob |
Thank you Bob,
the white plastic fixing (on the horizontal side) have the same distance of the old ones? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I did a quick check earlier and they did appear to be the same spacing - as far as LR tolerances go !
It looks like it is just a job of drilling holes in each door for the front and rear side fixings - plus waxoyl Mike ![]() Bob |
