|  | Home > Puma (Tdci) > Whistle / squeal from engine bay |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | Is this from under the hood Or the left Seat? a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  25th Mar 2018 3:09pm |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | On a some what more serious note.
 Don’t think it’s exhaust related. My bet is on the serpentine belt. Worm belt and Or tensioner arm. Have you checked that already? a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  25th Mar 2018 3:12pm |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | &€@&&x*^%^>%% dutch autocorrection
 Yes worn belt. Worn serpentine belt a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  25th Mar 2018 3:42pm |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | Ps soot takes a while before visable a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  25th Mar 2018 3:43pm |
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455      | Fixed! It turned out to be the joint between the turbo and the downpipe.
 There was no sooting but as Tdi4 said I guess it takes a while to show and this has only been happening for less than 100miles. My vehicle has got a non standard downpipe and I had to make some bolts up. I don’t think you’re supposed to use exhaust sealant but I put it back together with a smear of it and tightened it all up with the rattle gun. Job done! | ||
|  25th Mar 2018 8:17pm |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | Congratz. Good job done   a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  26th Mar 2018 4:34am |
| Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340      | good news
 You may laugh, I did that to find out if my turbo actuator was working. You do get some strange looks driving around with no bonnet  | ||
|  26th Mar 2018 4:43am |
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455      | Thanks for the help. There’ll no doubt be something else broken by the end of the week   | ||
|  26th Mar 2018 4:56am |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | I’ll be ready and waiting. Wasn’t expecting anything less    a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  26th Mar 2018 5:26am |
| v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455      | Slight update on this one which might help others
 The noise reappeared after a little while, most noticeably after a long run when the vehicle was really hot. I think just doing the exhaust bolts just altered the tension on the turbo. Turns out it was the turbo to manifold gasket after all, you can see the sooting on the old gasket.....   Click image to enlarge It should be noted that you couldn’t see any sooting outside the flange itself. Will be fitting a Nakatanenga one | ||
|  17th Apr 2018 7:27pm |
| Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340      | a nice easy fix then    | ||
|  25th Apr 2018 4:20am |
| mrjsray Member Since: 02 Jun 2017 Location: Cotswolds Posts: 10      | Mine's doing exactly the same thing.  How easy is it to change that gasket?  And is it going to do my car any harm by not fixing it immediately? | ||
|  23rd Jul 2018 11:21am |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513      | Very easy fix.
 I would do it sooner than later. But you haven’t leave the car on the side of the road and immediately call the workshop. Can it hurt the engine? The answer is no. But if it’s gotten bad enough (the leak) you can get an under boost dtc and go into limp mode. a defender from 1984 pretending to be a puma with a touch of Range Rover | ||
|  23rd Jul 2018 2:12pm |
 I wouldn’t say it will do any harm, I ran mine for a bit while I waited to have a new gasket to be delivered, and then finding the time to do it, so it was probably a couple of weeks or so. It’s easy enough to change, although a bit fiddly if you’ve got a bunch of bananas for hands like me. I’ve changed the turbo on mine before so compared to that it was easy. I can’t remember exactly but I think you can get away with unbolting the turbo and the bracket to the block and slip the new one in. I would thoroughly recommend getting the thicker gasket. It’s expensive but worth every penny. Not had any problems since | ||
|  23rd Jul 2018 5:23pm |
| Posting Rules
