Home > Maintenance & Modifications > Side window kits
JonJop
United Kingdom 1996 Defender 90 300 Tdi HT Arles Blue
Side window kits
Hi all
I’m wanting to put some side windows into my 1996 Defender 90 300 tdi van.
Has anyone purchased and fitted a set and can recommend a supplier/provide feedback on the quality and job itself?
Thanks
Post #695892 24th Mar 2018 3:09pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Did mine myself , got a set off eBay and the sealant , must admit I think I measured the opening about20 times before cutting Wink
If your fitting or got the interior use that as a template ,Mark inside then drill small holes to the outside and just do ,dot to dot. Thumbs Up
Post #695948 24th Mar 2018 8:08pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Post #695962 24th Mar 2018 9:24pm
tolley
I got one here is you want it ,template , but it was miles out with my interior, if your not fitting some should be ok.
Post #696016 25th Mar 2018 9:36am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
I put original windows in the Puma ones, Not much more than aftermarket if you haggle and look good with no fear of being unavailable in the future
Post #696030 25th Mar 2018 11:27am
EuropeDefender
Italy 1998 Defender 90 300 Tdi SW Coniston Green
I can only give an advice:
Buy OEM parts when you find them!
Far better of any after market!!! Si Vis Pacem Para Bellum
Post #702486 22nd Apr 2018 9:29pm
Scamperbid
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
I fitted the Masai fixed windows to my Defender PUMA. Measured it several times and rechecked several times before drilling and then cutting with a jigsaw. Use plenty of masking tape on the outer side panel to prevent the base of the jigsaw from scuffing the paintwork. I bought and used their template which worked fine although I would say it cuts a hole which is perhaps a couple of mm wider than needed and meant I needed to be careful when drilling the holes for the rivets.
Masai have a video on their website and there is also a YouTube Wheeler Dealer video that has some good tips.
One other point, I went for fixed windows from a security perspective however, with the warmer weather now coming, I now realise that sliding windows might have been a better option as I often have the dog with me and the additional through flow of air would be useful. As always, choices to be made!
Post #702496 22nd Apr 2018 9:53pm
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
The Masai template is an utter waste of time and money. It needs to be made of card to be of use as something that big made of paper with a huge hole in the middle has too much play to be any use as a temple.
Save your money or buy a tape measure and a Sharpie instead. Measure 50 times and cut once.
I have the Masai windows which came with the template. Windows were shoddy quality and rattle even though they are single/fixed pane. I would avoid the windows (and the template) and don't make the same mistake as me and cut the hole, fit the windows only to then discover they're rubbish, as there's little chance to send them back unless you like having an open sided van... Phil
Post #702500 22nd Apr 2018 10:00pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
That's vaulable feedback regarding Masai Window Window Kits, been looking at them for a 110 X 4.
Will need to rethink my plans now...
Thanks
Andy Working towards Carry on camping!
Post #702545 23rd Apr 2018 6:16am
Scamperbid
To be balanced, I have had no issues with the windows in terms of rattles!
Post #702553 23rd Apr 2018 9:56am
Andy80
Hi Scamper,
Are your windows Masai or another aftermarket?
Thanks
Post #702767 24th Apr 2018 7:46am
Scamperbid
Masai.
Post #702770 24th Apr 2018 7:53am
