![]() | Home > Maintenance & Modifications > Squeaky clutch?.....Easy mod! |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Nice mod i had the squeeky clutch pedal on my old 300 Tdi never did sort it,wish i had known about this then it used to drive me nuts. 2005 Td5 90 XS
Steve |
patclan Member Since: 13 May 2010 Location: Gold Coast Posts: 20 ![]() ![]() ![]() |
I have been suffering from squeaky clucth syndrome for a year, I have sprayed every possible lubricant up behind the pedal and found only temporary relief. I will be trying this as soon as I get the nipple..
Thanks heaps for that. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Thanks boet!
How is the 110 coming along? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Hi Naks
I just love that 110 RAW/X-tex. But I do miss the 90. Just PITA to start from scratch with all the mods....but I guess it is half the fun ![]() Must just mention that this was a plan made by a local forum member on 4x4community.co.za |
Vanderbult Member Since: 28 Oct 2015 Location: amsterdam Posts: 20 ![]() ![]() ![]() |
Some models do not have any silicone there but some models do???? If there is silicone (you'll easily feel it) try your bestest to get all of it of/out the hole.
i have a 90 "2011 model and mine has the silicon in the whole, how do i get it out? |
next to some silicon there is also some sort of bush or small bolt in the thread, do i have to remove that before fitting a grease nipple?
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
nice tip, thanks!
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I’ve done this but it’s not working at the moment
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Cool tip
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
It didn´t work for me either, so I opened the top cover, (philips screws) and grease the "pulling joint" (you will see). I used Moliketo grease. And its working ok without squeaky Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
It’s in for service tomorrow they said they would do it.
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
That looks good that, Ill have to pick up some nipples
![]() Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Is this threaded hole on the Puma as well? Specifically the 2.4. I thought I saw similar when looking at it the other day ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
It was on mine. Did the mod and it worked a treat. |
