![]() | Home > Maintenance & Modifications > Britpart Aluminium Ladder - DA3073 |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Thnx for the fast reply
![]() So this isn’t my solution unfortunately ![]() If have a safety device roll cage with different mounting Points for the ladder a defender from 1984 pretending to be a puma with a touch of Range Rover |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 575 ![]() ![]() ![]() |
Here’s my ladder, it sits in the gutter and also has 2 bolts through the rear roof panel and 2 bolts on the bottom. It does not obscure the number plate at about +- 30 degrees to each side. Don’t know the make but it may be a genuine LR one as the roof rack is.
![]() Click image to enlarge 2010 Defender 110 Station Wagon, Santorini Black. |
Ironically, that's exactly the same ladder as I have on my 90:
![]() Click image to enlarge I'd discounted it, partly because it bolts on and partly because the supports that press against the body are very close to the lights. I plan to fit NAS lights and that will interfere. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11052 ![]() ![]() |
I spotted this and my passenger took a pic for me as another method for the number plate to be seen more easily with a ladder to the rack. The red arrow is to show you were the number plate light is located, hope this helps
![]() ![]() Click image to enlarge ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Cost for An obscured plate this can be £600 plant hire business i work of that using magnetic registration plates driver being stopped and fine (ANPR camera cannot read the number.) |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2149 ![]() ![]() ![]() |
Have now replaced my landrover ladder with a frontrunner one and jolly nice it is too! (had to have it bolted at the top as the pop top requires the roof gutter to be part of the raising roof )
![]() ![]() Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
ssg Member Since: 01 Mar 2018 Location: North East Posts: 65 ![]() ![]() |
I have a Britpart ladder fitted that covers the number plate as in the original post and I did drill the top mount and bolted it to the rear of the roof, must remember to remove it at MOT time........
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
![]() Click image to enlarge Britpart ladder, for the money it’s actually surprisingly good! Plus Schnauzer blending into tent ![]() . |
