Home > Tdi > Brake fluid warning light - MOT failure
90roy
Hi,
Hoping you guys can help. The truck failed on 2 things
1. Rear ladder obscuring the number plate (it's been on there 4 years and they only just mention it now.... Wtf? - anyway sorted as I removed the ladder... For now.
2. Brake fluid warning light not coming on when ignition is first switched on as bulb check. This one's a bit harder. I bought a new reservoir cap and this has made no difference, the level sender works fine and if I remove the cap the bulb on the dash lights up but it still does not come on in test mode before I start it up.
Do you have any ideas where I could start looking please?
Ta,
Roy 300tdi 90 1996.
Post #695479 22nd Mar 2018 8:12pm
srod
What about your handbrake light?
Same light for both handbrake and fluid level is it not? Maybe just handbrake switch at fault?
Post #695486 22nd Mar 2018 8:30pm
90roy
Never thought of that srod. Where is the switch located? 300tdi 90 1996.
Post #695489 22nd Mar 2018 8:39pm
jonny
Re: Brake fluid warning light - MOT failure
Does it not come on when the engine is cranking, not when the ignition is on but the engine isn't running? I'm pretty sure on my v8 it does that..
Post #695499 22nd Mar 2018 9:01pm
90roy
No it doesn't Jonny.
I had to check just now though.. 300tdi 90 1996.
Post #695502 22nd Mar 2018 9:04pm
srod
It's at the base of the handbrake lever, possibly under the rubber gaiter, so an easy one!
Does your your handbrake light come on, when the handbrake is on...?
Post #695503 22nd Mar 2018 9:16pm
90roy
Actually no it doesn't srod.
I'll have to strip it down tomorrow and have a look.
Thanks.
Roy 300tdi 90 1996.
Post #695515 22nd Mar 2018 10:06pm
grafty99
The brake fluid warning light doesn't come on with ignition to test. It only comes on if the brake fluid is low or the handbrake is on Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #695518 22nd Mar 2018 10:14pm
Retroanaconda
It should come on with the starter crank as a light test. There is a relay that performs this function, wiring diagrams will show it.
The handbrake switch was not fitted to most Defenders, only higher spec models.
Post #695546 22nd Mar 2018 11:04pm
grafty99
My parents 300 definitely doesn't and hasn't failed an mot because of it Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #695591 23rd Mar 2018 8:32am
dorsetsmith
As stated there is a relay that performs this function, shown on this wiring diagrams see the link
https://www.defender2.net/gallery/albums/u...le0006.PDF
Post #695595 23rd Mar 2018 8:40am
90roy
Thanks guys.
Where will the relay be located? In fuse box area in the cab or engine bay?
TIA.
Roy 300tdi 90 1996.
Post #695652 23rd Mar 2018 12:32pm
dorsetsmith
fuse box area in the cab i think 4 one from left hand side
Post #695673 23rd Mar 2018 1:47pm
90roy
Many thanks for the help and suggestions.
I found a corroded wire to the handbrake cable which was the issue.
It definitely helped me knowing where to look / start which made this a relatively easy fix.
Roy 300tdi 90 1996.
Post #695859 24th Mar 2018 11:17am
EuropeDefender
Italy 1998 Defender 90 300 Tdi SW Coniston Green
Hi.
My 300 hasn't any test light function.
Only glow plug light. Si Vis Pacem Para Bellum
Post #698113 2nd Apr 2018 9:32pm
