Home > Maintenance & Modifications > Horn. (Upgrade)
Page 3 of 3 <123
donmacn
Keith5 wrote:
I went with the 300hz one and then ran a new cable direct from the aux fuse box so that the existing cable operated the relay. Its a tight fit behind the light cluster but fitted in the end.
It's not ridiculously loud and does sound better than the stock one.
Thanks Keith, I can see two issues there actually - one is that my horn is in the original location behind the grill - I don't have the vents in the wing/headlight panel that would allow it to sound properly if fitted inside the wing... Would that matter?
Secondly, I must admit I haven't had a detailed look at the electrical circuit yet, and the manual isn't handy right now. So the standard horn is wired through a relay? Did you put a fuse on your new cable?
The Nautilus things look pretty reasonably priced (by LR maintenance/modification standards!) so it's figuring out what's going to work best.
Intercept - that's a good find! Bet you're looking forward to hearing what they sound like! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #695427 22nd Mar 2018 2:13pm
Page 3 of 3 <123
