![]() | Home > In Car Electronics > Defender Security - Immobilise via inertia switch |
ssg Member Since: 01 Mar 2018 Location: North East Posts: 65 ![]() ![]() |
Fidely....
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
Thanks. I was referring to "unless it's off which does take a while to restart once reactivated"
![]() A couple of minutes... Seems a little inconvenient to use in some situations. Seems the ECU has to perform some post-emergency checks/inits. |
No don't get me wrong, that only happens if you try and start the car with the cut off activated. I did it on purpose to check!
aaah, ok! I didn't realise you can (re)start the engine with the inertia switch activated, even if it takes a while, after an accident.
So no delay in everyday use. That's good. cheers Frank |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
Hope they get one done for he 2.4 Puma soon My 90 Project : http://www.defender2.net/forum/topic52774.html
