Home > Puma (Tdci) > Brake fluid change with abs systems
Vitesse
Hi. Apologies if this is a stupid question, but is a brake fluid change and the subsequent bleeding
Process, any more difficult on a defender fitted with abs?? Thanks for any assistance Bow down 2015 90 XS Santorini Black
Post #694790 19th Mar 2018 11:24pm
zsd-puma
No. Some systems have a purge mode you have to put the pump into with a computer. But this is only really where you've fitted a new pump and need to prime it. For just a fluid change you can do it the normal way, either manually or with a pressure/vacuum bleeder.
Pressure bleeders are well worth their money.
Post #694807 20th Mar 2018 12:48am
Vitesse
Many thanks 👍 2015 90 XS Santorini Black
Post #695003 20th Mar 2018 8:59pm
