![]() | Home > My Defender > Introducing Buggsy my 110 TD5 |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Yep good old push rod brakes, no cables or hoses in sight, all the blokes I work with were amazed how the brakes work as they had never seen anything like it
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Little job for tonight, the No 1 ball joint boot was shredded and the steering damper bushes were looking a little flat so time to fit some new bits
Click image to enlarge Click image to enlarge All necessary parts well coated in copper slip for future tracking etc 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
And being flat
Yep makes a good work bench
Small job update, in the bid to rectify the spongy brake pedal I decided to have a rummage in the trailer and pulled out two new front callipers and some pads, no idea on the fitting kit location so had to refit the old one until the new one arrives; Click image to enlarge Click image to enlarge With all this work I might be able to see the back of the trailer soon 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
If it's an artic trailer, then no chance you will see the back of it
You can always make a bracket and then bolt it to the vice and then on to the drop/adjustable plate on the dixon bate hitch, then you would have one ready and waiting when you need it and different heights 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Not quite she’s only a 20’ box trailer
Great minds think a like Clayton 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Buggsy did her first drive today and to be fair it went well, no overheating, no warning lights and no worrying wobbles A few points; brakes still a little spongy for my liking so more work needed. The light bar definitely doesn’t light up the 361 very well Oh and if you thought I had forgotten about the first line: Click image to enlarge No idea how but my HD drive flange but decided it would be better bouncing down what I think was the A35 So now I need to buy a new pair, oh and a center trim for the wheel 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
Not bad for a first drive - could be worse!
I did think the sun took a while to set last night 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
It could of indeed been worse grafty, ah I did let the sun set, I might of sped up sunrise to start at 0300
Well Buggsy is now fully registered and insured
Cool
Will be keeping an eye out for you 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
| All times are GMT |
