- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
kipperthedog
Maybe getting somewhere.....
The dim-dip does not work when the sidelights are on. I have located the relay and will try bridging it. Too dark now.
The other possible candidate is the VW 99 wiper relay so will swap that for the original Lucas relay too,
A painful process of elimination.......
20th Mar 2018 6:57pm |
kipperthedog
In case anyone is interested......
I checked the circuit diagrams and found that everything not working shared earth header C0289 and then on to C0550. So I took off the earth from the heater blower switch and fitted a jumper lead instead and it worked. C0289 behind the instruments looked OK so I moved on. C0550 is well hidden under the coolant header which has to be moved. I unbolted the header and used the jumper to a good earth and everything worked. I cleaned the bulkhead stud, header tag and nut with isopropanol, reassembled and ...Happy Days...everything works again. Added a good dollop of grease to the stud and put everything back together.
26th Mar 2018 3:38pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
