Home > Puma (Tdci) > Urgent ... Tapping!
Greyman110
Urgent ... Tapping!
Currently in a services on the M1.
Loud tapping not the usual engine noise so I pulled over.
Had a look under the bonnet and it seems to be coming from the area closest to where the oil filler cap is.
Any advice right now appreciated as I have a long way to go!
Post #694506 18th Mar 2018 10:05pm
LR90XS2011
loose injector possibly can you feel them moving DEFENDER 90 TDCI XS,
Post #694508 18th Mar 2018 10:09pm
Greyman110
Yes..it's bouncing up and down.
Tried to start the car and it fired up but didn't sound happy starting
Post #694511 18th Mar 2018 10:11pm
LR90XS2011
if you have some tools whip the cover off and tighten the retaining bolt a bit to get you home DEFENDER 90 TDCI XS,
Post #694512 18th Mar 2018 10:18pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
As above ^^^
You need an 8mm socket or spanner, just nip the clamp bolt up, which is under the black plastic cover between the two injectors.
That should sort it and get you home. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #694513 18th Mar 2018 10:18pm
Greyman110
Thanks guys... unfortunately don't have any tools and I'm on my way to Birmingham for a couple of days.
I'll have to call out roadside assistance...I think i voted in the poll on that too!
Post #694515 18th Mar 2018 10:21pm
Greyman110
No technicians available so being recovered.
Post #694524 18th Mar 2018 10:45pm
agentmulder
Kuwait
Censored ... Well, you're not alone. Thumbs Up
Google 'defender2.net puma loose injector bolt clamp' or similar, lots of discussion, the basics are: nip them up to get home, get new bolts, don't go threadlocking them, best to get the seals replaced too. Solved the bowel problem, working on the consonants...
Post #694586 19th Mar 2018 11:21am
Greyman110
Much appreciated!
That's exactly what it is too! I've spoken to the dealer and they have been really helpful.
They are going to send me new bolts and if I can I'll do the seals too.
Thanks for the help...especially the quick replies when I was stuck in the services!
Post #694621 19th Mar 2018 1:33pm
