Home > Technical > Adding extra sensors to the Puma CAN Bus?
Cupboard
I'd like to an an EGT gauge to my Defender. I already have an Ultragauge that shows lots of useful information that it's picking up from the vehicle's CAN network. I don't want to add another display to the dash of my car, I'd like the Ultragauge to display the EGT temperature.
I think it should be possible to add another sensor to the existing CAN system. The hackiest way of doing it would be to buy a thermocouple, interface that with an Arduino and get the Arduino to talk CAN, that much is all within my capabilities. What I don't know is if any other part of the car will start complaining there's a sensor it's not expecting, or whether the Ultraguage will cope with an additional sensor that isn't part of the original installation.
Has anyone done anything like this before?
Post #694339 18th Mar 2018 1:28pm
UtilityTruck
Does the ultra gauge have any additional inputs? A second CAN Input for example? I suspect putting additional info on the vehicle bus would be very tricky and could cause issues with existing systems. 2014 Keswick Utility 2.2
Post #694369 18th Mar 2018 2:36pm
grafty99
As long as you can find all of the module addresses and initialization codes to make sure you don't generate a conflict then I don't see why it wouldn't work, what would the network do with an unexpected code? It's hard to say but I would imagine just ignore it.
The Ultragauge should pick up any CAN signal I would imagine? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #694457 18th Mar 2018 5:54pm
