Home > Wheels & Tyres > Change tyres
Eduardo
Change tyres
Hi there!
Today I went to change 2 tyres of the Defender due the wearing. I lost 2 tyres and I replace it around 1 year ago and the others have already 140,000 km on the clock.
I use BG Goodrich AT KO2 and ss the old ones was bought around 1 year ago now the tyres pattern design have changed. The vendor suggest me (according the tyre manufacturer) to change all of them.
As the others are barely new (still more than 5 mm thread) I reject to change all and I put the new ones in the front and the "old" ones in the back.
Do you see any issue in use 2 tyres (same manufacturer, same size) but with different thread pattern?
Cheers to all! Eduardo
Post #693624 15th Mar 2018 9:36pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Nope. I wouldn’t have a problem with this.
But did you change the front tyres diagonally to the back? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #693626 15th Mar 2018 9:54pm
Eduardo
Yep
Olders ones in the back and new onesin the front. Eduardo
Post #693804 16th Mar 2018 6:37pm
What's the difference in the actual rolling diameter between the old & new tyres?
Post #693817 16th Mar 2018 7:34pm
UtilityTruck
How old are the old ones? the recommendation is to change them at 10 Years old, regardless of wear. Also at 5mm tread the tyre will be much less effective off road or when wet-braking. 2014 Keswick Utility 2.2
Post #693822 16th Mar 2018 8:03pm
