![]() | Home > Maintenance & Modifications > Brake Pedal Squeak Fixed |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
Simple fix to this one, haven't seen in mentioned before.
Probably only applies to 15+16 model year Defenders with DSC. The two brake switch plungers (orange arrows) rub on the striker plates (green arrows) as you start to press the pedal. ![]() Click image to enlarge Just smear a tiny bit of grease on the striker plates to stop the plungers squeaking ![]() You don't even need to remove the plastic brake switch cover ![]() ![]() ![]() Last edited by Martin on 14th Mar 2018 5:24pm. Edited 1 time in total |
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 ![]() ![]() ![]() |
Thanks I’ve been meaning to sort this out for a while! Pic isn’t loading for me.
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Unnecessary quote removed
Brilliant! My 2016 2.2 is squeaky & getting on my nerves...thanks! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains |
