![]() | Home > Td5 > TD5 Foam air filters |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
New TD5 foam performance filters are here , only �34+�5 postage to the UK inc vat
http://www.bellautoservices.co.uk/index.php?page=itg_filters Regards Pete |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Hi Pete, is the airbox the same on the Puma as the TD5?
Thanks Rich ![]() |
The TD5 filter does fit inside the puma air box but the size is slightly different.
Regards Pete |
I cant comment on ITG as it would not be fare to name a brand spacificly.
What i will say is from my experience in some cases a foam filter can cause maf errors, i think and again im not 100%, its possibily because the airflow of the foam filter is to great and it takes the maf out of range. Or its possibile the oil used on the filter contaminating the maf. Which is why now i only fit standard paper filters to the puma. Regards Pete |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8342 ![]() ![]() ![]() |
cheers Pete
interesting as the td5 Maf didnt have that problem did it Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Remember its a different maf running different tollerances on a totaly different engine management system,
but yes it is intresting that some cause problems even tho they are totaly different systems, you would have thaught they would be ok in 100% of cases. Regards Pete |
