Home > Technical > Interior Light Stays on NOT switches
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
Hi
hope someone might have had the same issue and resolved it. I have searched using a number of different terms but cant find a match
Had to take the front interior light fitting out of the headlining for some firtling
Put it back, didnt work, recalled one of the studs touching the back of the fitting and hearing a click, seems like i touched the grounded plate captive stud to the switched line from the module under the dash. Checked fuses and replaced the blown one, now the lights come on when i open the door but wont dim and go out anymore.
I did see a post mentioning a programming option in the ecu but not sure why it would change or if it even applies to the tdci version
All door switches checked and working, checked under dash controller, everything plugged in.
Did notice the orange slate wire with a bare end, seems this is the aerial wire for the unit. is a bare end a good idea, if it touches ground wont help with reception, worth extending it to make the range better.
any help greatfully received
regards
chris
Post #691654 7th Mar 2018 9:40am
Screbble
Did you solve this pme?
I can't help you I'm afraid but I am interested to hear what it is/was Thumbs Up
Post #691921 8th Mar 2018 12:34pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Have you tried releasing the light from the headlining and leaving it hanging to see if it works then? It may be getting a short somewhere when you fixed it back up.
Post #691925 8th Mar 2018 12:48pm
Are you saying that the light stays on all the time regardless of what you do with the doors, or does the light come on when you open a door and go off immediately when you close the door?
It isn't clear from your post (at least not to me) what the light is actually doing.
Post #691927 8th Mar 2018 12:51pm
agentmulder
Kuwait
Careful that the piece pictured here (or similar) hasn't bent upwards and caused a short to the 10AS telling it you want the courtesy lights on permanently:
 Solved the bowel problem, working on the consonants...
Post #691929 8th Mar 2018 12:59pm
pme
Agentmulder, dinner for two with sculley on me (with wine) Razz
The piece was exactly as you described, (not the first to have this issue?) The tang was not bent over to locate the track properly, now works fine.
Blackwolf, yes the light stayed on with the switch in the "courtesy"middle position regardless of door position or engine running etc.
rgds
pme
Post #691944 8th Mar 2018 2:03pm
Screbble
Good result Thumbs Up
The forum demonstrates its worth again - and of course hats off to agentmulder Thumbs Up
Post #691955 8th Mar 2018 2:37pm
agentmulder
Kuwait
Oh great, my pleasure Thumbs Up .
That picture is from my rear internal fixture, I had the issue for weeks, was about to swap out the 10AS but decided to have a last look at the wiring. Pulling it out I realised that the logic worked with the rear fixture removed. I was then lucky to be looking at it from the angle you see..
Although it appears to be a rare issue, I consider it a design fault. It didn't happen with me fiddling with lining, it just started on it's own accord with speed bumps, then hills, then permanently on. Solved the bowel problem, working on the consonants...
Post #692047 8th Mar 2018 8:41pm
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I had a fault similar found the door switch was intermittent.
The door switches looked to be working when tested but in operation the fault would occur.
So manually pressing the switch it appeared to work but something must have been set up wrong.
Post #692120 9th Mar 2018 8:03am
Upgrade your interior lights to Mud units and you don't have this problem.
You need sunglasses, but you don't have the always-on or always-blowing-fuses problems!
Post #692137 9th Mar 2018 9:54am
Crofter
Mud units? I have not heard of these do you have any more info?
Post #692140 9th Mar 2018 10:01am
Post #692144 9th Mar 2018 10:17am
grafty99
How useful is the red illumination in real terms? I wonder if they would do a retina burning dual white one? (Or two) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #692306 9th Mar 2018 9:56pm
I don't often use the red, I have to admit, although there is no doubt that it doesn't affect your night vision like the white does.
Post #692331 9th Mar 2018 11:35pm
grafty99
Good to know Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #692339 9th Mar 2018 11:50pm
