![]() | Home > 130 > Crew cab 2nd row seats storage |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17956 ![]() ![]() ![]() |
It's the most useful storage area on a double cab, you can pack all manner of stuff in there!
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Been trying to sort something out myself. Currently got a shoddy plastic drawer which I've forced in. Though I think I'll make something better from wood, or maybe ali (thatll cost me though)
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501 ![]() ![]() ![]() |
I assume the bolts, like on our 130, were for the middle seat passenger in a crash. The seats are from a 110 CSW but mounted more upright and therefore probably not designed to lock in that position on a DCPU? 1951 80" S1 2.0
Seats lock fine, just as in an SW. I think the bolts are just to stop rattles and frustrate the owner!
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I unbolted the seat backs for storage
It's certainly cavernous ![]() Click image to enlarge But what about the space with the seatbox - anyone made use of that? |
On a 110 there is no space in the seatbox, it's full of chassis. On the 130 there is a huge wasted space because the chassis is flat under the seat. See AndrewS's "Longshanks" build thread for pictures.
Ah - that might be what was confusing me - I knew I had seen some photos of a removed seatbox...
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
Pre-puma 130s have a removable cover to access the storage area. I put Puma 110 seats in my 130 and found they don’t fit exactly right even with the correct brackets for the rear of the seat. I think Puma 130s must have a slightly different mounting foot for the front of the seat.
One thing I’m contemplating is getting old squar 130 doors and having a drawer from each side of that’s rear seat box. |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 225 ![]() ![]() ![]() |
I’ve seen I picture where someone had. Put a cabinet hinge on the little triangle bit of body with a sliding bolt to lock it in place. And had then fitted a draw in the seat box.
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 729 ![]() ![]() ![]() |
I’m in the process of affixing the triangular piece to the door so that there’s a square opening, I have a pair of drawers to fit in then where the seat box is. Then either a rear seat from a RR classic or a pair of puma fronts in on the modded seat box..
That’s the plan, anyway.. Cheers alex 98 300 tdi 90 project 88 200tdi project soft top 96 disco 1 jap import 79 911 sc 08 130 double cab utility |
remer Member Since: 29 Oct 2016 Location: Perth Posts: 4 ![]() ![]() ![]() |
Heres my setup, really handy for compressor hoses, tyre deflaters, common tools etc
![]() Click image to enlarge Last edited by remer on 10th Mar 2018 11:39pm. Edited 1 time in total |
Here you go:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
And a couple of other pics I took inspiration from
