![]() | Home > Camping, Caravanning and Holidays > OzTent and Campmor tents in bad weather |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1322 ![]() ![]() ![]() |
Hi,
I have an Oztent RV-3 ( and a number of other tents). My experience is as follows: 1) Biggest issue is the pack size - its around 2m long when packed and as I have a cargo barrier, I have to carry it on the roof bars. Again, roof bars have to be spaced suitably to carry the tent ( I have three bars). 2) Condensation - this was an issue till i got the fly-sheet which stays on permanently. But it adds to the pitch time as its four more guy lines 3) Robustness of material/leaks - touch wood not had any issues so far 4) Dealer support - heard bad things but luckily never had to contact them. I believe it will stand up to strong winds but I think there are also other tents out there that could do the job This Robens Klondike tent looks awesome and if I didn't already have too many I would get one http://www.robens.de/en/Products/tents/outback/klondike |
Howling Moon do a similar tent to the Oztent - see here
https://www.flatdoguk.com/wizz-24~1617 |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
I’m looking for a new tent currently, the Jet Tent by Oz tent is currently at the top of my list. It’s more expensive than the oz tent but the 2m long pack size kills the oz for me- I don’t want it on the roof.
I understand the f25/x comes with a fly that goes over the top giving double layering where the rain would hit. I’m hoping I can look at one local to me, I see Boab are based not far away so I will try them. 2014 Keswick Utility 2.2 |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
Tentipi with a fire - warm, tall, quick to put up and will withstand gales
![]() Click image to enlarge ![]() Click image to enlarge |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Apart from using Oztents we actually sell them so that is declaration of interest done!
Yes the 30 second bit is advertising blurb. Yes 30 seconds out of bag and upright but then have to peg it out. Oztents leaking? Very rare. Yes we have had Oztents out in very wet conditions. Condensation? Normally due to misuse of the tent. Use the ventilation flaps correctly and no problem. We do not normally use a flysheet and have only experienced minor condensation once. A flysheet would have solved that. Poles? Drill a 6mm hole in rubber foot and spray some WD40 sometimes. There was an issue with the plastic collars on the poles splitting 2 or 3 years ago. That issue seems to have been resolved now. Broken poles NO. We have very few issues with Oztents. Normally they are obvious on first putting up tent. Had a zip sewn in the wrong way but we just exchanged the tent. If used correctly the Oztent is a good tent. Do not use it correctly then you may have issues. Ye other companies have tried to copy it but in my opinion not same quality HTH Brendan |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I've had an RV4 for many years and recently also acquired an RV3 and an RV1. Our RV4 has withstood many a storm - in fact we bought it after using it to shelter from a huge rainstorm in the dealers demo field. The reputation for condensation hasn't ever affected us, but then we always leave the top & rear flaps open to give night time ventilation. Many people try to keep a tent warm - this is the problem: tents are to keep you dry and out of the wind. Sleeping bags and clothing etc are for warmth.
The 30 sec pitch thing is nonsense. You can make it look like a shelter in 30 sec but little more. Like many tents it takes a good while to properly guy it out, even if you don't bother with them all. Dealer support? Only ever needed it to report 2 missing poles from a kit. They arrived the day after reporting their absence. I like the modularity of the RV range, and how they can be interfaced to vehicles and trailers. The 2m pack length hasn't ever been a problem - the RV4 even fitted into my Lightweight - one end against the windscreen and the other resting on the top of the tailgate. Nowadays they all go inside the 101 or on the roof rack of the 110. I was previously a mountain tent user, in fact my Terra Nova Quasar is still part of the camping essentials kit as a teenager bedroom. |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I'm not sure what the facination with OZ tents are as a ground dwelling tent, it seems to be a marketing ploy towards adventure or overlanding people, there are a wealth of tents available which serve the same purpose and are a fraction of the cost.
Wild country/Terra nova tents are used worldwide in extreme conditions, i've used mine in Iraq, Norway and bonny Scotland and although this is a smaller 2 man tent ( it was strapped to a mountain bike in Wales for a week ) i have a 5 man which is bullet proof as well. Seperate fly sheet is stuffed in it's own bag when wet and used the following night, it doesn't affect the inner and you're kept dry. I had a quick look for you http://www.terra-nova.co.uk/tents-and-spar...ing-tent-/ well under half the price of an Oz tent and provides you with what you need. |
To address your point about drying out, with the Oztent you have to dry it out by pitching - as the frame system is built into the tent you cannot just hang it up in a shed as you would a conventional tent. never been a major issue for me though.
I hope I didn't give you the wrong impression - I really like the tent and use it a lot. I even have the sides so the awning area is well sheltered. At a recent gathering of canoeists, during a heavy downpour, I had quite a few taking shelter under the Oztent awning. If you get too many attachments though it will take ages to put up. |
[url=https://flic.kr/p/23Nwn39]
+1 for the. Tentipi, I have a Safir 9 which me and the wife used with an Oztent king goanna stretcher each (before the kids came along). If we are stopping for a couple of day we put the floor in, if just over night we don’t bother with the floor. people do take the ![]() ![]() 2011MY 110 XS USW Black |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
I’ll be putting one of these up for sale.
Great bit of kit, seems pretty bomb proof. Not the lightest tent out there but the metal poles are very strong. You can fit in a couple of stretcher beds in at either side with space down the middle. I’m 6’3’’ & can stand up in it. If you want any more info on it just pm me ![]() http://www.flatdoguk.com/safari%2ddome%2d2%2e5m%7e2432 |
deejayen Member Since: 18 Sep 2017 Location: Inverness Posts: 56 ![]() ![]() |
Thanks very much for all the info and pictures.
I'll need to weigh up all the pros and cons of the different designs, and try to think how I might actually use the tent. I've come across a bad review of a Campmor tent - it makes me wonder if perhaps some of the Australian and South African tents aren't quite ideal for our weather conditions. I looked into the Tentip range about 10 years ago -I still have the 2008 catalogue. I think one of those might be good, but I was put off by a Youtube video I saw a few months ago which made it look really complicated to set up with the floor, inner tent and stove. I think all the pulleys and straps for opening the vents were confusing. However, I'll maybe look into them again. I'm not sure if a Safir 5 would be too small. I think one site says it's a bit small for a fire, but perhaps one of the Heat Pal things would be a good option. Do you find that floors and inner tents are necessary (especially when midgies are about)? |
I don’t have an inner tent and have never had an issue with midgies.
In the top there is a fly sheet that you roll away when the stove is fitted or pull out when not. The pulleys aren’t that had by when you open the top in conjunction with the lower vents you get a really well ventilated tent with no midgies. When we set up I set out the pegs, we hook the tent up and the the wife goes in with the centre pole. I then tension the tent while she puts the floor in. I was able to try one out where I met Boode and had to have one. Russell 2011MY 110 XS USW Black |
Scottish midges in mid summer if not extremely heavy rain, then good inbuilt groundsheet and mosquito netting.
Just be careful about reviews on the net. People are more prone to put up bad reviews rather then good reviews. Brendan |
