![]() | Home > Td5 > Fitting a buzzer to indicators |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8322 ![]() ![]() ![]() |
Try taking of the steering wheel and checking the self cancelling arms are forgot in right position 12/6 when straight ahead, and then not broken. Cheers
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2216 ![]() ![]() ![]() |
Or just glance down at your dash. The flashy bit tells you the indicators are on...
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Funny thing mine don’t cancel one way and won’t stay on the other at certain locks.
^^^ you need to adjust the 'fork' behind the steering wheel it wasnt centered prior to the wheel going on. Cheers
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5129 ![]() ![]() ![]() |
On the blue forked collar, there is an arrow which should be aligned to the left with the self-cancelling arms at 12 o'clock and six o'clock.
Some aftermarket rings are black and I am not sure if those have the arrow alignment mark. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
I've used something like this before:
![]() but it was from Maplins - https://www.maplin.co.uk/p/12v-miniature-buzzer-fl40t Just pick up the power to the dash indicator light and take a feed from it. Not sure if there isn't an audible relay that could be swapped out, but then you might not hear it. Or as all the previous posters have said...just fix the actual issue ![]() |
