![]() | Home > Puma (Tdci) > Back seats gone fluffy! |
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
I have a bristle brush with velcro like material on one side. This is good for shifting bobbles which are not too firmly affixed.
Otherwise have you tried sellotape? |
| Snorkers Member Since: 10 Oct 2015 Location: Grampian Posts: 34
Morning Ian.
I have had similar issues with the carpeting on the back of other car seats. The flocking seems to tease out and you get left with longer strands hanging out unsightly. It may seem like a wind up, but using sharp hairdressing scissors I've trimmed them back flush with the undamaged material and they always come up great. Its a bit time consuming but great if you've OCD. Don't start off with Swiss army knife scissors like I did. You'll go mad ! Try it out and you'll see its not a wind up. I've not got one of those fuzz-away jumper bobble away gizmos that are always advised by JML and the like, but they might also work. Hope this helps Regards. Snorkers. |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
I used Wahl clippers on mine... Not kidding. Solved the bowel problem, working on the consonants...
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 538 |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
Hi chaps
Thanks for your reply’s and tips. I know it sounds a bit harsh, but I got my blow torch out in the end! It actually worked a treat, just a very quick flash over, and the fuzz has gone I probably wouldn’t recommend this on a new motor, But it’s worked for me Cheers guys 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502
Very British Leyland solution there Ian
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
Or you can use a disposable razor.keep rubbing with it until the fluff is gone. Also works a treat on wooly jumper bobbles !
The seats would be better off out of it really, I’ve only used them once in the last 4 years Wanted, Forward Control Anything considered. |
| All times are GMT |
