Home > Puma (Tdci) > Running in a new engine!
Zagato
I can't find anything in the manual about running in the new engine. I know engines these days are meant to be ready to go off the shelf but I thought there would be at least some kind of gentler break in period.
I have just bought a four stroke outboard motor and two new 2 stroke engines all of which have strict guidance for running in Confused
I havn't gone over 2500 rpm anyway just in case....
Post #68961 28th Apr 2011 8:08pm
mse
You will find none.
To be honest they get thrapped as they leave the line and probably a few times between built and you.
Anyway - there is some info on searches here...i would just enjoy it - advice for the range rover was keep it below 3k for the first 1000 miles - it wasnt always achieved but i did. Mike
Post #68965 28th Apr 2011 8:34pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
My 2008 manual says the following (page 68, seen as page 88 in online version):
RUNNING-IN
The engine, gearbox, tyres and brakes, need
time to bed-in. During the first 800 km (500
miles), it is essential that the vehicle is driven
with consideration for the running-in process.
During the running in period, the following
advice should be followed.
• Limit the engine speed to a maximum of
3000 rpm and the road speed to a
maximum of 80 km/h (50 mph).
• Do not use full accelerator pedal travel and
use the gears to avoid over-revving or
labouring the engine.
• Avoid rapid acceleration or heavy braking
wherever possible.
• Ensure that servicing is carried out on time
and follow any advice regarding use in
arduous conditions.
Note: The advice given for running in will aid
fuel economy and should be adopted as
general driving practice, even after the running
in period. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #68971 28th Apr 2011 9:01pm
Zagato
Thanks for that Mr Flips Thumbs Up
I have only done about 50 miles since getting her (150 in total!) and have been driving very thoughtfully. Clutch is all good, goes into the gears nicely with no nasty clunks. Engine runs fine and even with no roughness.
I asked the question as I remember I did give it some oomph one time when I test drove her and got a severe look from the salesman Shocked (probably only 3000 -3500 rpm. It had been his daily commute car and was looking after it BUT I am surprised there is nothing in the later handbooks unless I have missed it but thanks - common sense says let it bed in and free off at first.........
Post #68978 28th Apr 2011 10:07pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
thrash it from new otherwise things will glaze over not bed in properly and it will drink oil late in life, thats what the rev limiter is for Thumbs Up
Post #69007 29th Apr 2011 9:24am
RED-DOT
Aberdeen overdrive downhill and Italian de-coke uphill.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #69013 29th Apr 2011 10:33am
Zagato
Yeah thats what they say AND it makes a faster engine in the end apparently. The SAAB rally engines were hammered from the outset and gave more power compared to the ones that had been nursed.... Twisted Evil
Post #69034 29th Apr 2011 5:57pm
RED-DOT
I believe all engines are run flat out on the test bed prior to crating out to end user... just enjoy???? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #69036 29th Apr 2011 6:02pm
Alive Tuning
My puma 110 only has 400 miles on the clock. 200 of those were between 80-98mph (speedo reading) on a drive down the M1 to Derby. Whistle
As said above, drive it hard, and It'll make for a better engine. Diesels love it! Mr. Green
Post #69040 29th Apr 2011 6:56pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
...But my wallet doesn't Smile
Then again the occasional hoof doesn't make much difference, and if it keeps things healthy in the long run I don't care that much, Big Black's fuel economy gets better when it's driven less like an old boffer!
Post #69331 2nd May 2011 2:27pm
