|  | Home > My Defender > New Zealand Td5 |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096    | As said, cracking job    Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. | ||
|  29th Nov 2017 9:22pm |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096    | Very nice present you got there    Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. | ||
|  27th Dec 2017 10:00pm |
| hinsonberger Member Since: 31 Mar 2017 Location: Thames Posts: 32      | Small job fitting the towing socket into it's correct home       Click image to enlarge Nice to get little things sorted. | ||
|  1st Jan 2018 7:30pm |
| hinsonberger Member Since: 31 Mar 2017 Location: Thames Posts: 32      | Cubby Box Install
 Whilst nice (but not often utilised) to have 10 seats, I had always intended to remove the front row middle seat & replace it with a cubby box. I didn't want to spend too much, so decided to go for a Britpart one. With our Defender having the XS interior, I considered whether to go with an XS trim box, or a plain black vinyl one. I scoured the net for images & found a few, & made a decision to go with the plain vinyl one. Just a personal preference on what I thought looked best really! The middle row seat came out fairly easily, although the access to the bolts at the rear where a little restricted, plus I had to get assistance from the wife holding the bolted while I undid the nuts from beneath the vehicle. There where rivnuts installed in the centre cover plate under the seat, which I used to mount the cubby box. After rechecking measurements several times, I drilled the base of the cubby box as well as cutting & painting some wooden blocks to lift the box to the correct height & bolted it in with some 75mm long bolts. I did have a bit of a challenge removing the cupholder (as that's where the front bolts needed to go through the base), as it is glued in, but after some advice on here; I used a wide scraper with some sustained pressure to lever it out. I also didn't bother to glue it back in as I figured being able to remove it for cleaning might be useful.   Click image to enlarge   Click image to enlarge I also wanted some cupholders for the kids in the middle row seats, so bought some inexpensive folding cupholders & screwed them to the rear of the cubby box.   Click image to enlarge   Click image to enlarge Overall I'm happy with how it turned out & it's very nice having a place to put the coffee cup, plus all the other bits & pieces you end up carrying around. | ||
|  30th Jan 2018 9:02am |
| hinsonberger Member Since: 31 Mar 2017 Location: Thames Posts: 32      | Life Hammers
 Installed two original Life Hammers:   Click image to enlarge   Click image to enlarge Also; I’m sure the heater/blower is stronger since installing the snow cowl. It definitely blows cooler air than it used to, which is a nice added benefit  | ||
|  5th Feb 2018 10:57pm |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772      | Top job    if you wanted a nice cubby lid exmoor trim sell cushioned ones in a few different trims including xs. Ray My build thread http://www.defender2.net/forum/topic17615.html | ||
|  6th Feb 2018 12:20am |
 Thanks! I'll add it to the list of potential future enhancements, along with all the other priorities I've got on there  | ||
|  7th Feb 2018 3:22am |
| hinsonberger Member Since: 31 Mar 2017 Location: Thames Posts: 32      | Small improvement made today:
   Click image to enlarge Second hand off eBay. Pretty cheap & came from Spain! A nice improvement that adds a nice improved functionality. | ||
|  2nd Mar 2018 7:02pm |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946      | Great work.    James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers | ||
|  2nd Mar 2018 7:39pm |
| hinsonberger Member Since: 31 Mar 2017 Location: Thames Posts: 32      | Another small job on the driver's & passenger's seatbelts:
   Click image to enlarge | ||
|  24th Mar 2018 3:56am |
| Posting Rules
