Home > Puma (Tdci) > what is the 2.2 Puma battery type
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
On the MY2014 2.2 Puma engine what type of battery should I use?
I think it is a smart alternator so do I have to use a silver calcium battery.
The one in it is a genuine Jag/Land Rover part and is a standard lead/acid type which I think was fitted by Land Rover.
If I need a silver calcium type battery can anyone recomend what to use?
Post #689863 1st Mar 2018 8:05am
ericvv
Puma no smart alternator. Standard wet cell battery will do, otherwise LR would never have installed it, no?
If you do a search on here you will get a zillion threads on batteries. Like the one below for instance. The most educated battery explanation and advise is given by user tatra805. First thread below, worth reading.
Eric
http://www.defender2.net/forum/topic16605....arta+lfd90
http://www.defender2.net/forum/topic54344....p;start=15 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #689865 1st Mar 2018 8:18am
zsd-puma
The alternator is just a normal one.
I fitted a Yuasa battery from Halfords. 5 year warranty, same size and a greater capacity and CCA than the factory battery.
Genuine batteries are good and last well, but they're not magical as some would have you believe. They are however extremely expensive. About £200 last time I looked, which is twice what I paid for my Yuasa one which will from experience last much longer than the 5 year warranty.
While Land Rover batteries do generally last many years, they still only come with the standard 2 year Land Rover parts warranty.
Post #689944 1st Mar 2018 1:46pm
ibexman
Varta LFD 90 Thumbs Up
Post #689949 1st Mar 2018 2:00pm
foggydave
Hi zsd What was the reference for the Yuasa please?
Post #690026 1st Mar 2018 6:55pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Varta every time Thumbs Up
Post #690034 1st Mar 2018 7:30pm
zsd-puma
It's an 019. This one;
http://www.halfords.com/motoring/bulbs-bla...ar-battery
Post #690137 2nd Mar 2018 7:26am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Magneti Marelli ETS100D1N
100Ah 1000A (EN), 650A (ICE)
L=353
B=175
H=190 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #690156 2nd Mar 2018 9:31am
Theater
VARTA Professional Dual Purpose AGM LA 95 - 840 095 085
https://www.varta-automotive.it/it-it/prod...40-095-085 Marco
Post #690164 2nd Mar 2018 9:48am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Yuasa are usually a good make, used them on bikes and stuff for years, but have not tried the larger ranges as they aren't readily available here.
The best factory ones were about fifteen years ago, when they were Delphi - they lasted forever. I sold my Discovery 2 at 13 years old with the original Delphi factory fitted battery still in it, though it was getting a bit tired by then!
The later 'genuine parts' ones I think are now mostly Varta where there is branding, and whatever they fit appears to be much lower quality. I bought a 110Ah Td5 battery for my 300Tdi 110 about three or four years ago but they just don't seem to hold their charge like the old ones did, on a vehicle that is not used much, mine doesn't have an alarm or anything to drain it either. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #690683 3rd Mar 2018 10:23pm
