![]() | Home > Puma (Tdci) > Greasing front propshaft |
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 409
This is quite interesting.. Have been following this range of tutorials recently.
&t=69s 2015 90 XS Santorini Black |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Doesn't anyone fit grease nipple protectors anymore? Keeps the muck out.
Merlin |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18046
It would appear not.
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
The only 'grease nipples' with protectors I know are the brake bleeding plugs.
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Never seen any on a propshaft - wouldn't they just fly off any fast moving parts?
I've always fitted grease nipple covers and haven't lost one yet off of a UJ or prop shaft. I bought them off eBay, search for RUBBER GREASE NIPPLE COVERS.
| nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720
Guys, what is the recommended frequency for greasing the props. Thanks
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
10,000km or 6 mouth
| Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 538 |
@UtilityTruck
Did you jack up from under the axle? If you jack it up from under the chassis, this then let's the axles hang down - you still need the tyres off the ground, and this gives max axle travel / drop which widens the gap at the side of the universal joint - you should then be able to get the grease gun in then. Sometimes you can get into the joint from the side at around 2 to 3 o'clock if that makes sense. A decent trolley jack and a block of wood under the chassis rail helps |
| UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463
Grouse - I must admit I jacked under the axle. Now you mention it, it’s obvious letting the axle droop will help access. I’ve got a needle adaptor for my grease gun on order- I shall report back if this gives sufficient access to do the front prop. If not I’ll have to stop putting off buying a new trolley jack. Oh well! 2014 Keswick Utility 2.2
| GrouseII Member Since: 29 Dec 2017 Location: Bucks Posts: 37
Oops, just happened to see your post.
I have been posting signing as Grouse rather than my official GrouseII username. I doff my cap to you sir and apologise. I will sign as GrouseII from now on to avoid miss representation GrouseII |
No problem
| All times are GMT |
