![]() | Home > Maintenance & Modifications > TD5 T7 Pre-Heater - now air in system? |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Hi Steve. Sounds like you have done everything right. The TD5 is supposed to be a "self bleeding" system, however I always find that aiding the bleeding by pumping whatever coolant hoses I can reach helps to dislodge errant bubbles.
Other methods include getting the coolant up to temperature, then parking the vehicle nose up on a slope for 15-20mins. This will help with trapped air in the heater matrix. After that it is a case of doing a number of hot-cold-hot-cold-etc and keeping an eye on the coolant level, topping up as necessary. Keep a bottle of pre-diluted anti-freeze in your cab. Could I ask for a few pictures of your T7 setup please? |
| steve_c3 Member Since: 30 Apr 2015 Location: Hants Posts: 179
Thanks for the reply and good tip on the hill, I'll try and do it over the weekend - also got a premixed bottle ready for top ups.
This is the install below. The first pic shows it in position but with the old Kenlowe heater still in there. The second photo shows it all connected up. Its a neat little unit and all enclosed so no separate pump like the Kenlowe. Initial test looked good and it got the block temp up to about 75 degrees. This was in the workshop so no chill factor to take into account. It's not speedy but it is only the 2kw version - the Kenlowe that came off was a 3Kw. At £75 delivered, it's worth a shot! The power comes from a socket mounted on the front bumper that I plug a mains cable into. Once I'm happy theres no air left in the system, I'll do a proper timed test on it and post the results. Click image to enlarge Click image to enlarge 2002 Defender 110 CSW TD5 |
Super install. Have pondered on these heaters for many years, hotfrogs and alike.
You have mounted that heater very low down so I do not expect there will be any trapped air in it, if anywhere it will be in the heater matrix or quirky little ports in the engine. |
I've just had another quick look at this at work and found the following...can anyone confirm if this sounds right?
Coolant at correct level for Cold. Preheater on for 10mins - block gets up to 20 degrees. Preheater on for 20mins - block still at 20 degrees - previously this has got to 75degrees. Coolant bottle feels cold. Top pipe feels warm. Remove bleed screw - coolant coming out. Turn off preheater and start the engine, run for 10mins to get a bit more heat in. Expansion bottle is now 3/4 full. Engine still running, Open bleed screw. Get nothing. Remove bleed screw - still nothing. Squeeze top pipe - still nothing. Like theres nothing in it. Loosen cap on expansion tank - top pipe fills with coolant and starts spurting out - replace screw quickly! It seems that once the coolant gets to about 20degrees the top pipe empties? 2002 Defender 110 CSW TD5 |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge B for 1998 to 2002 cooling system A for 2002 to 2006 EU3 cooling system showing flow your new heater has a pump built in |
Thanks for the info. I guess the thing I need to know is whether the top hose should be full of coolant at all times even when the engine is stone cold? Could anyone enlighten me by giving their hose a squeeze
Mine seems to empty when its cold and I don't know whether it always has or if it even should? If it shouldn't drain then I need to investigate why. 2002 Defender 110 CSW TD5 |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
the top hose out of the rad? yes that should always be full of coolant. there shouldnt be any air in the coolant system.
is the flow through the preheater the correct way around? when you say the block gets to 20Deg do you mean the reading on scanguage/temp sender or you user lazer thermometer? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
James, that’s what I thought. I’ve got a laser thermometer so have been using that to check temps. I’ll check the hoses again in the morning when it’s cold and see if lifting the coolant bottle to help gravity do it’s job does anything and top up if need be. 2002 Defender 110 CSW TD5
Does the preheater try to pump coolant the wrong way and the system, thermostat? Stops it going all way around so it signed in air one end ?
If you just run the engine does the top hose empty? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| All times are GMT |
