![]() | Home > Td5 > More heat needed |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I'm going to be positive about the Puma.... I had the window open on the way in today..heater speed 1 and I was boiling
![]() The td5's heater is woeful. QRZ 2e0vpf |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Thanks that helps.....
Can a Puma heater be fitted to a TD5? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5355 ![]() ![]() |
get some of graftys vents Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I have some - and they are ace. But need more heat! 1999 Defender TD5 110
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I have the issue that my new heater matrix is so efficient that it just cools the TD5 engine back down again in cool weather! 02' 110 TD5 Double Cab Rebuild Thread
What matrix do you have? 1999 Defender TD5 110
just a new OE one 02' 110 TD5 Double Cab Rebuild Thread
Worth the effort? Did you swap because of lack of heat? 1999 Defender TD5 110
I actually swapped it out because of a coolant leak from the end of my old matrix, however the new one (along with replacing the foam insulation within the heater box) is much more efficient that the old one (which wasnt visibly corroded or blocked that i know of). Trouble is you have to hold off turning the fan up until the engine has warmed up fully in cold weather or it cools the engine back down.
I did see an Alisport uprated heater matrix however. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Cheers for the info Steve. I might have a look into the matrix side of things.
I don't have Alisport money. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Part of the issue is the lower part of the dash is basically the whole of the piping before it gets to the piddly little vents.
Even a brand new matrix isn't great (have one on the V8 ) and they are a lot warmer running than the td5! Maybe a diesel heater like Eberspacher? QRZ 2e0vpf |
Woeful? Poppycock... It is adequate when dressed correctly... Besides, follow these simple rules for dress code and you'll make it through to Spring; ![]() Click image to enlarge |
Unfortunately not. |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
Rad muff might work
