Home > Td5 > transfer box whine in reverse
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
Hi all
When reversing in low range, get a very distinct whine from what I think is the transfer box. Does not whine in forward gears, and no whine when in high range.
Vehicle is a TD5 03 plate.
Any thoughts much appreciated.
Post #689218 27th Feb 2018 10:37am
roel
Could it be the clutch? Mine does the same sometimes and I am preety sure it is the clutch. Roel
2003 90 Td5 (2009-now)
Post #689220 27th Feb 2018 10:45am
Why would a clutch whine in one direction and not the other (assuming that you're not slipping it, of course)?
More likely to be a gear-train somewhere, but I would have thought the reverse idler gear in the main box was a more likely candidate.
Unless it is a really bad whine I wouldn't worry about it, most vehicles make some gear noise going backwards.
Post #689234 27th Feb 2018 11:02am
roel
Mine makes noise while slipping the clutch but only in reverse not when going forward. I don't understand it either but it happens. When it is not slipping anymore the noise is gone. Roel
Post #689290 27th Feb 2018 3:01pm
Mo Murphy
Reverse gear has straight cut teeth which are noisy.
50 Shades of Pennine Grey
Post #689299 27th Feb 2018 3:23pm
That is extremely weird and defies logical explanation!
Post #689301 27th Feb 2018 3:28pm
geobloke
Mo
Agree with Mo on this one. I also note that since having the Ashcroft HD bearings fitted to my transfer box there is generally more bearing noise than with the standard bearings.
Post #689313 27th Feb 2018 3:58pm
Piggle
Thanks all for thoughts. Will not panic for now and get it checked in service next month.
Post #689627 28th Feb 2018 4:19pm
miker
My transfer box whines in every forward gear above about 30! Has done for the last 30k and hasn't gotten any worse, so I elect to pretend it's fine!
Post #695605 23rd Mar 2018 9:35am
^^^ My Disco 2 has now started doing this, after 200,000 miles or so. Under power or under engine braking it makes a sound reminiscent of an underground train or a milk-float accelerating. Under conditions of very light power it is quiet. This pitch of the sound is speed related.
I can't decide if it is the transfer box or the main box, but, since I have a spare transfer box, I think it is more likely to be the main gearbox!
I have found that turning up the music is the best solution for now.
Post #695650 23rd Mar 2018 12:27pm
miker
Yeah similar scenario, original Transfer, and done around 205k. Gearbox was changed out 20k ago and this noise remained!
Although mine is compounded by what feels like an excessive amount of backlash under light loads/downhills on motorways. I know it's not the rear drive flanges, but I haven't figured out what it is...
Post #695659 23rd Mar 2018 12:45pm
lightning
Change the oil in the gearbox and transfer box.
Post #695785 23rd Mar 2018 11:33pm
In my case changing the oil made absolutely no difference, but it was reassuring that the correct amount of very clean oil with no metal debris came out of both the main and transfer gearboxes.
Post #695788 23rd Mar 2018 11:45pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Have you tried the play in the tbox output shaft? I get a few noises as mine is worn and has a small amount of play. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #695823 24th Mar 2018 8:18am
