Home > Technical > defender 300tdi will only start when we bump start it
Bert@E
Netherlands
hello,
i bought a parts defender 300tdi and it will only start when we bump start it...
if i start it with the key it turns fast, but the engine does nothing, even not hesitate to start
any idea what the problem could be?
thanks
Post #689267 27th Feb 2018 2:04pm
grafty99
Starter turning it over too slowly? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #689270 27th Feb 2018 2:10pm
Bert@E
Netherlands
no fast, nothing to do with the starter
Post #689271 27th Feb 2018 2:11pm
rallysteve
Check that the fuel cutoff solenoid receives power when cranking. If the wiring has been messed with or the wrong ignition barrel switch been fitted it might not.
Post #689275 27th Feb 2018 2:19pm
Bert@E
Netherlands
i'll check that with a voltmeter, but why does it run when we bump start it?
Post #689293 27th Feb 2018 3:05pm
jst
If starter is faster then expected, the gear maybe damaged or not engaging on the throw or starter ring teeth missing
working on assumption - the engine does nothing, so its not turning over. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #689335 27th Feb 2018 6:02pm
rallysteve
because you presumably do not have the key in the crank position when bump starting it.... 02' 110 TD5 Double Cab Rebuild Thread
Post #689337 27th Feb 2018 6:08pm
Low-Range
Canada
Not starting
Sometimes the fuel has flowed backwards. For example if you run out of fuel a pull often will start a reluctant runner. I know this from experience.
Post #689340 27th Feb 2018 6:30pm
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I had the 300 version of the discovery, you can manually operate the pump and bleed the fuel system as I remember and that can rule out the fuel system.
Post #690170 2nd Mar 2018 10:15am
