Home > Puma (Tdci) > Puma 2.4 fuel economy got worse
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
Hi.
I bought my Defender 110 HT in summer 2015.
Since the beginning the fuel economy was very good (imho) - 10l/100km - 28mpg. Winch and 265/75R16 tyres.
I've made some trips, added A/C, added a full external roll-cage, full under-body protection and the fuel economy dropped a lot.
Now it is in the 12-13l/100km (22-24 MPG) at best.
I don't think it can be only caused by the extra weight of the roll-cage.
Another thing that I have noticed is a strange engine sound especially below 2000rpm - it sounds as the valves were loose but I don't think it can be the case in this engine.
ECU shows no errors.
Any ideas what could have happened, how to diagnose and how to improve it? Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #689095 26th Feb 2018 8:35pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Hi
You say you thought “the valves were loose”?
Do you mean like a tappet noise?
Depending on the mileage, it may be worth pulling the injectors and replacing the copper washers?
Maybe the VCV for good measure?
Both straight forward jobs, that make a great deal of difference.
How long since a filter change?
Obviously A/C has quite a big impact on fuel economy too, but I wouldn’t have thought a cage would make much difference? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #689097 26th Feb 2018 8:50pm
Bergos
Thank you.
The mileage values I gave are measured with the AC off.
The car has almost 140k km on the clock. Bergos
Post #689117 26th Feb 2018 9:31pm
Clean the MAF & MAP sensors, this can be done more or less for free and something you can rule out.
EGR is also a possible culprit, but normally involves the MIL. (Amber dash warning light). ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #689121 26th Feb 2018 9:39pm
miker
The weight of the underbody protection and rollcage won't make much difference. The extra aerodynamic drag however, definitely could!
I gain 3-4mpg by taking my roofrack off. It's just a massive pain and I have nowhere to keep it.
Post #689179 27th Feb 2018 1:17am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Interesting thread.
I use about 14l per 100 km whilst driving 120-130 km per hour.
I drive a 110 heavily modified it weighs about 2500 kilo with external roll cage
And driving with 6 people and lots of lugage
Normal city use is about 12 l per 100 km
I am intereted what other can get out of a liter of fuel
So burgos if you compare your Numbers we are in the same range a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #689198 27th Feb 2018 8:36am
Bergos
True, we are. The thing is that 2 years ago my car was using 10 litres per 100 km no matter how hard I was pushing it.
I see that some people have even better results.
So, something is definitely not right... Bergos
Post #689248 27th Feb 2018 12:05pm
jst
same size tyres?
cage, rack, protection all make a difference but not massive unless you pushing on at top end or alot of hard acceleration where the added mass will make some difference, but not 50% Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #689249 27th Feb 2018 12:10pm
Bergos
Yes, same tyre size, actually the same tyres...
I agree that the roll-cage and under-body shields can make some difference, but not that big. It's a Hard Top and the back of the car is always almost empty. I have 2 beds over there and some plastic boxes with stuff but nothing really heavy. Some people have better results with fully loaded cars...
I think I will start with the injectors washers and seals. Is there a kit for this engine or I have to buy separate parts?
I guess I would need:
Right? Bergos
Post #689256 27th Feb 2018 12:48pm
zsd-puma
Not from main dealers, you have to buy the separate parts, but don't get the washers from Land Rover they're "REALLY" expensive. Get them from a Diesel Injection specialist, they should only be about £1 each. Failing that get them from a Citroen dealer, they're about £7 each, but that's still less than half the price Land Rover charge and a couple of quid cheaper than Ford.
There are some transit kits on ebay for reasonable prices.
Post #689286 27th Feb 2018 2:37pm
Bergos
Yeah... I see those for example:
https://www.ebay.co.uk/itm/FUEL-INJECTOR-S...Swal5YHIYe
Where do the big, black seals go? I can not find them on any LR schemas...
 Bergos
Post #689288 27th Feb 2018 2:48pm
zsd-puma
the large seals go in the top of the cam cover, the injectors then go through them. Look under the plastic injector cover on the top of your engine and you can see them.
Post #689292 27th Feb 2018 3:03pm
Bergos
Ah, ok, so they are LR004650 as shown on https://www.landroverworkshop.com/diagrams...er_44988#8
So, the complete set consists of:
Right?
The set in Brit-car, without the bolts arrives to $48.60 +$10.50 for the bolts...
I think I will buy the kit from ebay... although I usually avoid buying cheap... Bergos
Post #689298 27th Feb 2018 3:19pm
Bergos
Hi guys!
I would like to share something with you. There has been an interesting and unexpected development in the topic of my cars economy.
Look at the graphs (l/100km and Imperial MPG) below:
The last fueling happened after 390 km on highway - 10l/100km.
The second last - 9.2l/100km - 550 km in mountains, which includes a little bit of off-road driving.
All previous fuelings that are below 12l/100km are done after driving country roads. Highway - never below 12l.
So, what happened at 145500 km? I put into my engine a bottle of Liqui Moly Ceratec.
Last oil change happened at 143950 km. Bergos
Post #734186 11th Oct 2018 12:07pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I'm personally quite wary with any sort of additives, either fuel or oil additives, because I reckon if they were of any benefit, LR would recommend their use (after all, it's the car manufacturer best interest to get better fuel economy or longevity for their engines)
Anyway, you may find this video interesting:
 “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #734194 11th Oct 2018 12:55pm
