![]() | Home > Td5 > Brake pipes!! |
1. Can I order a direct replacement yes 2. key thing you need its ABS or not, but having looked at your pic Id say none ABS can not see cable for abs sender and reg date i.e. 02 = 2A. Post CHASSIS NUMBER 4A front brake pipe changed abs or none abs end fitting are differentia
3. And is re bleeding the system straightforward yes, starting rear passenger side as pre LR work shop Manuel TD5 |
You can also make it yourself from copper pipe. Small investment in tools and copper pipe and you can make your own. Is one is in this state you might want to check the others too. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Cheers guys great advice. Had a look and it looks straightforward enough. Just bought all the bits and tools, gonna replace the lot. Will update on how it goes.
Cut the pipe just above the nut so you can use a socket. Roel
Good tip! Cheers.
Another question:
Do I need to drain down the system to take the damaged pipe out? Have just cut the damaged pipe above where it joins the flexi and brake fluid is continuing to drain out. Was expecting only minor fluid loss with the rest held in by the vacuum. Have plugged it for now and come in for me dinner. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
All the fluid from that circuit will drain out unless you take steps to prevent it, the easiest way being to wedge the brake pedal down. Alternatively remove the reservoir cap and put a poly bag or similar over the opening then replace the cap.
Cheers for the quick reply! Eaten me fried chicken and chips and a can of cider, now back to it.
Job is all done now. Replaced all the piping both left and right front. Had ordered new flexi hoses too but they are stuck in transit somewhere, so put the old ones back on for now. Flushed and bled the whole system. All went well, no major incidents everything came apart okay. I never knew new brake fluid was so clear
![]() Float switch in the reservoir was seized, so I have learned all about the wiring of the handbrake light on the dash, only real drama I had. Looks like I need new rear pads, so I think I'll do those, rebuild the rear calipers and replace the rear pipe work as my next project. |
