![]() | Home > For Sale & Wanted > [For Sale] 110 Chequer plate for load area and Modul System |
| Crossfit_Pete Member Since: 07 Feb 2018 Location: N.Essex Posts: 168
If only you were a bit nearer to Essex. Is the cut out for fuel pump access?
| davybull Member Since: 10 Dec 2017 Location: Wigan Posts: 54
Not sure Pete it just came like that with a separate plate in the hole.
Dave. |
| rodspink Member Since: 12 Apr 2015 Location: Aberdeenshire Posts: 187
Hey there.
Would you possibly sell the bulkhead piece seperate and stick in the post please. Would be so appreciated. Thanks Rod |
| DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299
Any chance of a measurement from the rear of the vehicle edge of the drawers, forwards to where the drawers stop and the shelves start? I have a 110USW with a partition in which is further back than normal and I'm wondering if they would fit?
Dimension as per this link: http://prntscr.com/ij6o28 I wouldn't want the bulkhead chequer so could split with Rod. North Cumbria Search and Rescue - Team Leader |
Hi Duncans,
It is all out of the vehicle now so I can only give you a measurement of the actual unit itself. The unit itself was attached to the joint between the roof and the body at the back of the vehicle. Units themselves are 805mm long. Cheers. Dave. |
