![]() | Home > In Car Electronics > TD5 Defender Ignition Live in the fuse box? |
do you have heater front screen
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
If you have electric windows then there is a relay in the fuse box with an ignition feed.
Should also be one (brown/purple) on the brown A/C connector in there Steve 02' 110 TD5 Double Cab Rebuild Thread |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
Full XS spec so all the goodies.
Thanks! What would be the best way of going about it without messing around too much? I have got a signal cable for a sub/amp could I tap into that to power the switch or would that mess with the sub/amp? |
I used this to tap into an existing fuse:
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Quite like that, where did you get it?
Any good local (web)shop in electronic parts, or Ebay: http://www.ebay.com/bhp/fuse-tap Cheers, Vincent
Cheers dude!
I ask as I've just fitted some light bars, which came with a wiring loom & switch (with a small LED thats always lit) Plan is the fit a switch pod on the dash eventually but I was bored so fitted the lights anyway... Reason I wanted the switched live is so that switch isnt live when the landy is off and thus no LED on. I imagine its a tiny current draw. |
![]() I used this to power my dashcam from ignition live, so it will start and stop automatically. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thats an even better idea! I hard wired mine into the cig lighter, though a perfect idea for the mrs hyundai
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Brown plug bottom left of fuse bos has an ign live in front of yellow relays 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
