![]() | Home > Puma (Tdci) > Greasing front propshaft |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
I’ve managed to do mine several times. Either your nipple had snapped
Instagram - @r22oyp Roy |
| UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463
Both front prop nipples are the same, neither have snapped and I’ve had the truck since new so I don’t think there is much chance of them having been swapped.. 2014 Keswick Utility 2.2
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
You should be able to grease the prop in place.
I've always done mine in place |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Nipple could have loosened, fasten it until you can either use it or you think you're going to shear it off.
That and a combo of letting off parking brake until its ideally positioned.. Solved the bowel problem, working on the consonants... |
| AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1373
I had same issue with my TD5 front prop, manual grease gun end was too big to fit between the UJ's, I had to use a different gun with a slimmer end.
Original grease gun did every other grease nipple no problem. Could hear the grease popping as it was pushed in |
| Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461
For the awkward "one" i use a chain saw grease pump on the ball valve.
Do you mean something like this?
https://www.clarkforest.com/shop/chainsaw/...rease-guns I’ll have to take a pic of my prop because I can’t see how that would help- there is just zero room... 2014 Keswick Utility 2.2 |
Thats the one but if you jack up the car on the driver side it opens the yoke up.
I’ll try jacking it and see if it opens up enough- many thanks. I was expecting to be able to do it with the truck on the ground. 2014 Keswick Utility 2.2
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8488
it depends on what grease nipple is on the UJ, they are not all the same, some are between spiders, some as in middle with angles head, some had the later with the angled head snapped off! just remove it axle end and grease whole things whilst manipulating the joints through full range of movements. Cheers
| InternationalDBA Member Since: 18 Feb 2018 Location: West Sussex Posts: 41
I struggle with this job too with my grease gun if the propshaft is on the vehicle.
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
As said jacking up one wheel and rotating for position works well! However with no threaded hole for a spline nipple too be fixed prop occasionally has too be removed! Special tool works there!
Click image to enlarge So... I jacked up the front so I could spin the front prop- the picture above shows what I found. Both ends are essentially the same- rotating the prop doesn’t really help- the nipple is shielded by the yoke. Is a right-angle, extremely low profile grease gun extension a thing? 2014 Keswick Utility 2.2 |
| Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306
That’s a handy place to put it!
| All times are GMT |
