Home > Technical > Harsh Vibration
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Harsh Vibration
Hi everyone before I’m shot down, I did search but only found one thread that seemed to describe my problem, but there was no conclusion!
Could a failing clutch / release bearing cause a harsh vibration through the vehicle?
The best way to describe it is - Imagine the feeling like you’ve shifted up to the wrong gear and really laboured the engine (ie like going to select 3rd but selected 5th instead)
I’ve got the classic signs my clutch is failing (very noisy release bearing at idle and clatter when switching off) and now this vibration has appeared which seems to be only when cold (ie first few miles of the day) and at low speed / gears. At first I thought it was Exhaust, but it’s all secure on inspection.
If not clutch, what else could it be?
Thanks in advance
Mark My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #688400 23rd Feb 2018 12:57pm
Vague as it sounds, check you don’t have and grit and stones in your tyre treads. If so remove it all.
If no change, or nonevpresent check prop UJ’s as well. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #688408 23rd Feb 2018 1:13pm
meeerrrk
That's Steve, I will check but it is a complety different feeling to something in the tyres.
Can the UJs be properly checked in situ? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #688409 23rd Feb 2018 1:19pm
A basic check yes, but you can't always fully check them.
Sometimes it's something you least expect that's the culprit, and often the most simple or cheap to fix.
Most of us jump the gun and expect the most expensive repair. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #688416 23rd Feb 2018 2:13pm
meeerrrk
That is very true Steve! thanks, i'll check them this weekend. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #688419 23rd Feb 2018 2:18pm
Given that you know it's an issue, I'd sort out the clutch first. You may be chasing a second problem that doesn't exist. Darren
Post #688423 23rd Feb 2018 2:40pm
meeerrrk
yes you are correct Mr Anorak....but I'm wincing at the £1k bill as already spend over that on maintenance in the last 2 months Sad My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #688426 23rd Feb 2018 2:42pm
Landyman61
South Africa 2014 Defender 90 Puma 2.2 CSW Tamar Blue
Check your rear tyres, if every second tread block on the inner side of the tyre has worn lower, it causes a vibration at low speed, more noticeable with cold tyres. Our local dealer replaced the rear diff twice under warranty and serviced the prop before checking the tyres. 2 new tyres and vibration has gone. My tyre dealer suggested rotation every 10,000 km to even out the wear.
Post #688712 25th Feb 2018 5:00am
Low-Range
Canada
Vibration
In gear and running
In gear with clutch in
In neutral and coasting
all tell a different story
Post #689344 27th Feb 2018 6:48pm
