![]() | Home > Puma (Tdci) > Integrated key & remote - does anyone make one ? |
| sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261
put me down for one
| yawlboy Member Since: 13 Mar 2008 Location: Cork/Waterford Border Posts: 18
and me 1993 110 200tdi Utility in Marine Blue
Gone - various FFRR, D3's, Discos and a Freelander or two. |
| xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258
Yeh as long as it's got a better range than the current one... which seems to be about 2m!
| Kez Member Since: 11 Apr 2011 Location: UK Posts: 271
I'll have one too
| pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568
Looks like a real improvement!
| Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610
The keys/blades are compatible, but the electronics in the fob are completely different. The Defender 10AS unit is made by Lucas (!), and the Disco 2 BCU is made by Valeo. The coding of the keys is totally different, so this is a non starter. I do away with the 10AS fobs anyhow, and replace them with clifford fobs. Much smaller, but still seperate. |
| daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246
Or alternatively, and this actually works, simply touch the fob to your head and it works from up to 30' away. Ideal in the pouring rain when you forget to lock it but are already inside drying off! 2001 TD5 110 DCPU in Bonatti Grey |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
3 for me (2 keys for everday and one like spare) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
aye, suppose if these actually work (i.e. can be programmed from the Nanocom) then I'll take a couple. How much are we talking about? 2001 TD5 110 DCPU in Bonatti Grey
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
I was sceptical about this for years, but it really does make a difference! Does anyone know why or how the human head has this effect, and what does using it in this way do to the contents? |
| 110 Member Since: 07 Apr 2011 Location: Nottingham Posts: 43
In my case it could only improve |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
big headed peoples open from 500 metres
| party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311
Doesn't the head somehow act as a signal amplifier????... never tried pointing it on other parts of the body to see if it has the same effect ........ but I think I've found a new game for tomorrow morning As to what effect it has..... hev\zhcf\vc zjjjjjhjjhjhjjj ..... none that I've noticed. Jon - 110 td5 [sold]. Currently Defenderless. |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Yes but if you modify it and use your head you get even further range...you head only takes you so far. Mike |
