Home > For Sale & Wanted > [For Sale] 2.8TGV Auto Def 90 Truck Cab Off Road Prepared
jst
Things move on and i am just not using this vehicles as much as i used to, 400miles last year in it.
£12,000 for:
1984 C Reg, 2.8TGV auto, Ashcrofts, Richards Galv chassis, td5 bulkhead etc etc Mot runs until Jan 19, 9k miles since rebuild in Nov 08. with TGV and Auto Box. total mileage on engine/auto/ashcrofts 19k miles. Complete history since i purchased it and rebuild it, all documented with DVLA for engine change and auto on V5
Garage stored, kept on battery conditioners, used hard, ball fully functional and no expense spared on maintenance/upkeep.
'84 Truck Cab 90
TGV 2.8 HS VVT 19k miles
Ashcroft Monster Auto Box HP24/22 amalgamation with 4.0 Torque Converter
Richard Galvanised Chassis
D2 air to oil cooler (gbox)
340mm Laminova Water to oil gbox cooler
Range rover disc rear axle
truck cab
ARB compressor
Gigglepin manifold
Allroad A6 air res aluminium
Front freespool
Rear freespool
Husky rear winch with Bow 1 & Albright, rear load bay mounted
North Offroad cage
8274-50 front winch, Bow 2 & albright
Wide angle fair lead
OME Springs +2"
OME front shocks std
Terrafirma Rear +2
HD tubular front -2 turrents
-2" rear drop top shcok mounts
Llama 4x4 +2" banjo to chassis brake cables front
110 front calipers
90 rear calipers
Llama std
Bearmach Blue bushes throughout
winch wiring to rear 35mm
winch wiring to front 50mm IIRC
Ashcroft 1.4 T box Aug 2005
Ashcroft Underdrive
Ashcroft CVs
Ashcroft HD front shafts
Ashcrfot HD rear shafts
Ashcroft drive members
ARB axle lockers x 2
Bowrope front and rear
2 x rear ali hawse
Gwyn Lewis rear trailing arms
Gwyn Lewis Rear WA prop
D44 WA front prop
Southdown rear detachable tow pack
Southdown steering guard
Southdown rear diff guard
Southdown weld on front diff guard
Gwyn Lewis uprated Sumo drag link (Disco)
Gwyn Lewis uprated Sumo track rod
Gwyn Lewis box section track rod protection
Gwyn Lewis (Disco) drop arm conversion
TD5 instruments + EGT, Volts, Boost
TD5 bulkhead & instrument panel
Ashcroft centre console
Spare Tub - complete.
Mod door bottoms
Rocky Mountain removable door tops
Internal winch controls
Puma heated seats (15MY)
Through cab snorkel
Rear chq plate side lockers
remote located Jump lead setup
Mach 5 rims 5 of
255.85R16 KM2s
X-Eng side rubbing sills ali.
X-Eng disc brake
Allisport Intercooler
Allisport Radiator
Have pics of the rebuild if required.
Will upload some pics of it in due course.
this vehicle will pretty much do anything you need from it Off Road as far as you can take a road legal vehicle. Has everything fitted you would require to compete too. This is a truck for fun and its brought me a great deal of happiness over last ten years. Will be sad to see it go. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #687785 20th Feb 2018 12:55pm
Gosh, that's not a lot of money!!!!!!!! QRZ 2e0vpf
Post #687804 20th Feb 2018 2:25pm
bankz5152
That sounds cracking!!! Any pics?
Post #687901 20th Feb 2018 8:59pm
darthdicky
I think this has forced me into a decision James! Give me a call when you get a chance.
Richard
Post #687934 20th Feb 2018 11:00pm
Mo Murphy
Go Dicky !
50 Shades of Pennine Grey
Post #687938 20th Feb 2018 11:19pm
jst
as requested some pics, but now sold, subject to payment.
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #687978 21st Feb 2018 11:19am
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #687979 21st Feb 2018 11:20am
jst
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #687984 21st Feb 2018 11:30am
Les Brock
Dicky raided the piggy bank ?? Rolling with laughter
Post #688002 21st Feb 2018 12:55pm
darthdicky
Yep, when's yours coming out again?!
Post #688161 22nd Feb 2018 8:39am
walfy
OOh, I remember helping James to fit the cage on this. Was an eventful day. Not laughed so much in a long time 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #689009 26th Feb 2018 3:07pm
TJ101
You will regret it,, But, gone to a good home Wink California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #689786 28th Feb 2018 10:19pm
jst
Sold Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #691269 5th Mar 2018 9:38pm
