Home > Td5 > 120 kph warning light (Alternate use)
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Can anyone illuminate (pun intended) on best how to use this warning light for another feature. This particular light is not active on my 2000MY 110 Td5 and I’d like to use this warning light for my front auxillary lights (switch seen below it). Which wires in the mutliplug can be used to activate the LED?
Thanks. šŸ‘
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #687571 19th Feb 2018 3:09pm
rallysteve
I use the warning light for my cruise control. Unfortunately however it requires connection to earth to illuminate rather than a positive signal so most applications will require a relay to switch it on.
Post #687600 19th Feb 2018 4:41pm
4RF RDS
I figured that would be the case as I use my choke warning for the heated screen. Which wires though? Do you know? My wiring diagrams do not show this warning light ā˜¹ļø 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #687604 19th Feb 2018 5:07pm
rallysteve
Pin 6 on the 20way black connector on the back of the warning lights
Post #687618 19th Feb 2018 5:57pm
4RF RDS
Thank you. Thumbs Up
šŸ» 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #687619 19th Feb 2018 6:01pm
