![]() | Home > Technical > Heated seats |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
My seats never get too hot, think you might have a problem there!
Ps I did it! Commented with no mention of your wife's hot ass ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Alex L Member Since: 22 Jan 2018 Location: South Northants Posts: 134 ![]() ![]() ![]() |
Mine is the exact opposite and neither of mine heat but both heater buttons illuminate. The dealer said to bring it back but that’s a 200mile round trip. I’m not electronically minded so no idea where to start but will see whether my new Corbeaus heat when I install them on Monday
Almost certainly means that the element has shorted out. Replacement is the only fix but in the meantime I'd disconnect it to prevent it being switched on by accident and catching fire. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4294 ![]() ![]() ![]() |
I can’t help diagnose the fault, but replacing the heater pad,is not difficult, I did it this weekend using an Exmoor trim one. If you have done a lot of miles, think about placing the foam too. 2007 110 TDCi Station Wagon XS
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 ![]() ![]() ![]() |
I'd agree with LandRoverAnorak, the element itself has probably shorted out. I'd expect if you left it on that it would blow a fuse if it already hasn't done so.
I had one go in a similar way on my old one - although I never felt the heat just a burning smell when I got back in the Landy so the fuse must have blown quite quickly. As said, they are relatively easy to replace. If I remember correctly the pad I bought didn't come with an OEM connector so I had to join it to the old one. You can probably get some with the right connectors though. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
The Exmoor ones have the OEM connector of them. Downside to that is that it is a bit tough to stretch the grommet in the seat base enough to fit it through. 2007 110 TDCi Station Wagon XS
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
I shall order a replacement asap, might be worth doing both to be safe
